Particle Argon IoT Development Board (Wi-Fi+Mesh+Bluetooth)
$27.50
SKU: DFR0611
Wi-Fi enabled development board with mesh networking, Bluetooth, Nordic nRF52840 processor, ESP32 coprocessor, large Flash and RAM, USB, Li-Po charging, FCC certified.
Purchase this product and earn 275 reward points, which are tied to VIP membership program. Learn More >
Particle Argon IoT Development Board (Wi‑Fi + Mesh + Bluetooth) combines Wi‑Fi connectivity with low‑power mesh networking in a compact development platform designed for scalable connected systems. Built around the Nordic nRF52840 microcontroller and supported by an integrated ESP32 Wi‑Fi coprocessor, this wireless IoT development board enables rapid deployment of connected devices and local mesh gateways. The compact hardware platform integrates high‑performance processing, extensive memory resources, and flexible connectivity interfaces, making the module suitable for advanced IoT prototyping, distributed sensor networks, and cloud‑connected embedded systems.
Note: Breadboard and USB cable are not included.
Dual Wireless Architecture for Flexible IoT Networking
This Wi‑Fi and mesh networking module integrates two complementary wireless systems: a Nordic nRF52840 SoC supporting Bluetooth and IEEE 802.15.4 mesh protocols, alongside a dedicated Wi‑Fi coprocessor. Such architecture enables operation either as a standalone Wi‑Fi endpoint or as a gateway connecting local mesh devices to cloud services. Reliable wireless communication and multi‑protocol support make this connectivity platform suitable for distributed IoT systems, smart sensors, and scalable device networks.
High‑Performance nRF52840 Processing Core
The compact embedded controller board uses an ARM Cortex‑M4F processor running at 64MHz with hardware floating‑point acceleration and DSP instruction support. Generous onboard resources, including 1MB flash and 256KB RAM, provide sufficient capacity for complex firmware and connected applications. Integrated peripherals, native USB capability, and extensive GPIO options allow rapid integration with sensors, actuators, and communication modules while maintaining efficient power consumption.
Integrated Cloud Connectivity and Device Management
This IoT connectivity platform is designed to work seamlessly with the Particle Device Cloud infrastructure. Built‑in support for over‑the‑air firmware updates, cloud APIs, and web‑based development tools simplifies remote device management and fleet deployment. Combined with the board’s Wi‑Fi gateway capability, large groups of mesh nodes can be connected, monitored, and updated through a unified cloud environment for scalable IoT system deployment.
Typical use cases include distributed environmental monitoring, wireless sensor gateways, smart home automation nodes, and rapid IoT prototyping platforms. The compact wireless development module also serves well in research labs, industrial proof‑of‑concept deployments, and STEM Education environments requiring reliable connectivity, flexible expansion interfaces, and cloud‑managed device infrastructure.
  • Nordic nRF52840 SoC with ARM Cortex‑M4F processor running at 64MHz
  • Integrated Wi‑Fi coprocessor supporting 802.11 b/g/n (2.4GHz)
  • Supports Bluetooth 5 and IEEE 802.15.4 mesh networking
  • 1MB Flash and 256KB RAM on the nRF52840 MCU
  • Additional 2MB SPI flash for application storage
  • 20 mixed‑signal GPIO including analog and PWM channels
  • Native USB support with Micro USB interface
  • Integrated Li‑Po battery charging circuit and battery connector
  • Onboard PCB antenna with optional external antenna connectors
  • RGB status LED and dedicated Reset and Mode buttons
  • Compatible with Particle Device Cloud for OTA updates and device management
  • IoT gateway and mesh network coordinator
  • Wireless environmental monitoring systems
  • Cloud‑connected sensor networks
  • Smart home and building automation
  • Industrial IoT prototyping
  • STEM education and embedded networking experiments
    Nordic Semiconductor nRF52840 SoC
  • ARM Cortex-M4F 32-bit processor @ 64MHz
  • 1MB flash, 256KB RAM
  • IEEE 802.15.4-2006: 250 Kbps
  • Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps
  • Supports DSP instructions, HW accelerated Floating Point Unit (FPU) calculations
  • ARM TrustZone CryptoCell-310 Cryptographic and Security module
  • Up to +8 dBm TX power (down to -20 dBm in 4 dB steps)
  • NFC-A tag
  • Espressif ESP32-D0WD 2.4 GHz Wi-Fi coprocessor
  • On-board 4MB flash for ESP32
  • 802.11 b/g/n support
  • 802.11 n (2.4 GHz), up to 150 Mbps
  • Main Parameters
  • On-board additional 2MB SPI flash
  • 20 mixed signal GPIO (6 x Analog, 8 x PWM), UART, I2C, SPI
  • Micro USB 2.0 full speed (12 Mbps)
  • Integrated Li-Po charging and battery connector
  • JTAG (SWD) Connector
  • RGB status LED
  • Reset and Mode buttons
  • On-board PCB antenna
  • U.FL connector for external antenna(one for thread/BLE, one for Wi-Fi)
  • FCC, CE and IC certified
  • RoHS compliant (lead-free)
  • Dimension: 51.0 x 23.0 x 15.5mm/2.01x0.91x0.61”
  • Weight: 8.8g
  • Particle Argon IoT Development Board (Wi‑Fi+Mesh+Bluetooth) x1
  • Out Of Stock
