Supply Voltage: 4.5~5.5V
Supply Current: (recommend using the adapter with the power of 2A and above)
Power Supply Interface: Micro-USB
Maximum Charge Current: 1.6A
Battery Port: PH2.0-2P or solderable contact
Battery: 3.7 Lithium Battery
Output Voltage: 5V
Maximum Output Current: 2A
Communication Interface: I2C
Dimension: 65x30mm/2.56x1.18”
Mounting Hole Size: 58x23mm/2.83x0.91”
Operating Temperature: -40℃~85℃
May 27, 2026
Polarity protection would be amazing on this. just burnt out a board because the battery manufacture miswired one of my batteries. My fault for not checking all of them but it still would be nice
Oct 21, 2025
It would be nice if it had reverse polarity protection -> I accidentally broke my first one because the battery I bought had the plug mounted incorrectly. Fits perfectly also on my RPi zero 2w
Oct 28, 2022
First I thought, why would I use it. But now that I had it for some time, I find it very useful for various types of applications. Only thing that I don't like is that will drain the battery if its left connected to the board for a long time.
