Supply Voltage: 4.5~5.5V
Supply Current: (recommend using the adapter with the power of 2A and above)
Power Supply Interface: Micro-USB
Maximum Charge Current: 1.6A
Battery Port: PH2.0-2P or solderable contact
Battery: 3.7 Lithium Battery
Output Voltage: 5V
Maximum Output Current: 2A
Communication Interface: I2C
Dimension: 65x30mm/2.56x1.18”
Mounting Hole Size: 58x23mm/2.83x0.91”
Operating Temperature: -40℃~85℃
Oct 21, 2025
It would be nice if it had reverse polarity protection -> I accidentally broke my first one because the battery I bought had the plug mounted incorrectly. Fits perfectly also on my RPi zero 2w
Oct 28, 2022
First I thought, why would I use it. But now that I had it for some time, I find it very useful for various types of applications. Only thing that I don't like is that will drain the battery if its left connected to the board for a long time.
