Metal Case for Raspberry Pi 4B (Dual fans)
$17.90
SKU: FIT0650
Raspberry Pi 4 alloy case features dual fans for enhanced cooling, open design for signal reception, and includes thermal silicone and assembly tools.
Raspberry Pi 4 Alloy case with dual fans.
Cut-out Design Simple and Aesthetic:
Open design, avoid signal isolation, no influence on Wi-Fi, and Bluetooth.
Dual fans, advance the cooling efficiency.
Dual fans, cooling, cooling efficiency, advance cooling efficiency, case
NOTE: two fans in case are not controlled by the program, they will turn on once the Raspberry Pi is powered.
  • Dimension: 87 * 56 * 25 mm / 3.4*2.2*1.0 inch
  • Weight: 101g
  • Material: aluminum alloy
  • Fan x2
  • Fan Operating Voltage: 5V
  • Fan Operating Current: <150 mA
  • Aluminum housing bottom x1
  • Aluminum housing top x1
  • Dual cooling fans x1
  • Thermal-conducting silicone x2
  • Hex screw x12
  • Hex wrench x1
