Are you still bothered by the Raspberry Pi fever problem? Don’t worry, we have prepared a cooling solution for the Raspberry Pi 4B. Aluminum heat sink is adopted due to its highly cooling feature and excellent resistance to oxidation, which can effectively avoid chip over-heating problem.
The surface is designed with slotting, which is more conducive to the discharge of heat. The heat sink comes with back glue, easy to use.
Black heat sink with adhesive (M): 14.3 * 9.9 mm / 0.56 * 0.39 inch
Black heat sink with adhesive (S): 9.1 * 9.1 mm / 0.36 *0.36 inch
Jan 21, 2025
Good and cheap product.
Jan 03, 2024
good and packing good
May 18, 2023
Very fast shipping. Thank you!
