The housing retains the installation space for the GPIO hole and the fan. GPIO port and camera ribbon cable can be elicited by the gap reserved at the top. The case installation will not affect the use of camera and GPIO ports at all. The bottom also has a screw hole for easy fixation on the wall.
Most of the shell surface is designed with hollow, which can help the motherboard to dissipate heat better.
NOTE: This product does not contain a Jetson Nano board nor an antenna.
