A 19-core shield is adopted in this wire to ensure the stable transmission of the signal. A gold-plated process is used in the wire end interface which can prevent oxidation effectively and increase the durability. Multiple plug-ins will not affect its function. PVC environmentally friendly exterior makes it strong and soft, antioxidant and corrosion resisting. So, even through multiple bending, as always, remains stable signal transmission.
It is not only suitable for Raspberry Pi 4B, but compatible with a wide range of devices such as notebooks, HDTVs, tablets, and projectors.
