Maix Bit AI Development Kit RISC-V K210 IoT
$33.00
SKU: KIT0155
AI development board with K210 chip supports MicroPython, OpenMV algorithms, neural networks, and includes LCD and camera. High speed, low cost, versatile.
Purchase this product and earn 330 reward points, which are tied to VIP membership program. Learn More >
Maix Bit AI Development Kit is a compact edge‑AI computing platform built around the K210 processor featuring a dual‑core RISC‑V architecture. The onboard AI chip integrates an independent FPU, 64‑bit CPU architecture, and 8MB on‑chip SRAM while operating at a nominal frequency of 400MHz. This embedded vision development platform combines high‑performance neural network acceleration with accessible MicroPython programming, creating an efficient solution for machine vision, embedded AI experimentation, and rapid prototyping. With integrated flash storage, camera and LCD interfaces, and built‑in peripherals, the compact AI board delivers powerful on‑device inference capability in a small footprint suitable for IoT innovation and intelligent sensing systems.
Maix Bit AI Development Kit RISC-V K210 IOT
Figure: Maix Bit AI Development Kit RISC-V K210 IOT
K210 RISC‑V AI Processor with High Computational Performance
The embedded AI computing board integrates the Kendryte K210 chip featuring a dual‑core 64‑bit RISC‑V CPU with hardware floating‑point unit support. Independent FPUs accelerate multiplication, division, and square‑root operations while dedicated neural‑network acceleration enables hundreds of GOPS of AI processing capability. Compared with traditional microcontroller‑based vision systems such as STM32H7 OpenMV implementations, this vision processing platform delivers dramatically higher algorithm throughput and significantly faster AI inference, making the module well suited for edge‑based machine learning tasks such as object detection and real‑time image analysis.
Integrated Vision and Display Interfaces
The compact AI development board measures only 53.3 × 25.4mm yet integrates a wide set of multimedia interfaces. A 24‑pin DVP camera connector supports sensors such as OV2640, OV7740, and OV5640, while an 8‑bit MCU LCD interface enables direct display output. The kit package includes a 2.4‑inch LCD and an M12 camera equipped with a 4mm HD lens and 650nm infrared cut filter. This combination forms a ready‑to‑use embedded vision platform capable of capturing, processing, and displaying image data directly on the device.
MicroPython AI Development Environment
The AI edge computing module runs MaixPy firmware, a MicroPython‑based environment designed for rapid AI and embedded development. The firmware provides simplified APIs for neural network operations and maintains compatibility with many OpenMV algorithms, allowing existing computer vision workflows to migrate easily. Integrated support for the nn class in MicroPython enables convenient neural network deployment while maintaining the accessibility of high‑level scripting for robotics prototyping, intelligent devices, and experimental machine‑learning projects.
The kit package includes the Maix Bit AI development board, a 2.4‑inch LCD display, and an M12 camera module with a 4mm focal‑length HD lens featuring a 650nm infrared cut filter. This compact AI vision kit forms a practical platform for embedded machine vision research, IoT edge intelligence, robotics sensing, and experimental computer‑vision applications.
  • MicroPython support
  • Compatible with most OpenMV algorithms
  • Support neural network algorithms, encapsulates the nn class of mpy
  • Neural network algorithm speed: hundreds of GOPS (thousands of times STM32)
  • Face detection speed: conventional algorithms 6 frames
  • OVGA, RGB image: AI accelerator can reach more than 60 frames
  • Debugging support: UART and JTAG interface
  • GPIO interface: all GPIOs are connected to Headers 2.54mm
  • DVP connector: 24P FPC connector(compatible with OV2640, OV7740, OV5640, etc.)
  • LCD connector: 8 bit MCU LCD 24P 0.5mm FPC connector
  • On-board MEMS microphone
  • On-board TF card slot
  • Main-controller chip: K210
  • Chip core: dual-core RISC-V 64bit IMAFDC
  • Main frequency: nominal 400M, can be overclocked to 600M
  • Memory: 6MB general memory+2MB AI memory
  • Flash: 16MB
  • Embedded machine vision systems
  • Edge AI object detection
  • Face recognition and tracking
  • Smart IoT devices
  • Robotics vision modules
  • AI algorithm experimentation
  • STEM Education and AI learning platforms
  • Dimension: 53.3x 25.4mm/2.101”
  • Input Voltage: 4.8~5.2 V
  • Input Current: >600mA
  • Temperature Rise: <30 K
  • Operating Temperature: -30~85 ºC
  • M12 Camera: 4mm focal length HD lens(with 650nm infrared cut filter)
  • 2.4” LCD Display
  • Maix Bit AI Development Board x1
  • LCD Display x1
  • M12 Camera x1
Only 19 Left
