Maix Go AI Development Kit RISC-V K210 IoT(Discontinued)
SKU: KIT0156
Discontinued
Note: Maix Go AI Development Kit RISC-V K210 IoT is discontinued now, we recommend Maix Bit AI Development Board RISC-V K210 IoT as a suitable replacement.
Maix GO development board adopts AI chip K210 of RISC kernel. K210 comes with dual-core processor chip with independent FPU, 64 bits CPU bit width, 8 MB on-chip SRAM, 400 adjustable nominal frequency, and double-precision FPU supporting multiplication, division, and square root operation. Besides, there are on-board accelerometer MSA300, audio encoding chip, MEMS microphone, etc. As the name suggests, this is really a ready-to-go kit!
The product features RISC frame, high performance, low price, AI, and MicroPython support. MaixPy firmware is micropython firmware, which makes it easy for everyone to use AI algorithms and the operation of conventional microcontrollers; MaixPy firmware is compatible with most APIs of OpenMV! Buying the MAIX development board is equivalent to having an OpenMV development board that is three times the price of the MAIX development board! And the measured power of the ordinary algorithm is 2~3 times of the original STM32H7 version! The power of the AI algorithm is even more than 1000 times that of the STM32H7 version of openmv! That's right, it's 1000 times!
Maix Go AI Development Kit RISC-V K210 IOT
The Kit includes:
  • Maix Go Development Board
  • Acrylic Case
  • 200 W Pixel M12 Camera (4mm focal length HD Lens)
  • 500mAH Lithium battery
  • 2.8”OVGA LCD
  • 1W Small Speaker
  • Type-C High-Quality USB Cable
  • WiFi Antenna
  • Controller Chip: K210
  • Chip Kernel: dual-core RISC-V 64bit IMAFDC
  • Main Frequency: nominal 400M, can be overclocked to 600M
  • Memory: 6MB general purpose memory+2MB AI memory
  • Flash: 16MB
  • MicroPython Support
  • Compatible with Most OpenMV Algorithms
  • Support Neural Network Algorithms: encapsulates the nnn class of mpy
  • Neural Network Algorithms Speed: hundreds of GOPS (thousands of times STM32)
  • Face Detection Speed: conventional algorithms 6 frames
  • Image Recognition: QVGA@60FPS/VGA@30FPS
  • Debugging Support: UART and JTAG interface
  • 3-Axis Digital Accelerometer: I2C interface
                                                          14 bits resolution,
                                                          selectable range: ±2g, ±4g, ±8g, ±16g
  • RTC: on-board 32.768K crystal connected with STM32F103
  • LCD Interface: Maix-LCD board (with resistive touch screen) is directly connected to the GO
  • GPIO Interface: all GPIOs connected to header 2*20P 2.54mm
  • DVP Camera Interface: 24P 0.5mm FPC connector
  • On-board MEMS Microphone
  • On-board TF Card Slot
  • Microphone Array Connector
  • Lithium Battery Port
  • USB Type-C Port
  • Audio Encoding Chip+Dual-channel Audio Amplifier
  • RGB LED
  • 200W Camera, M12 lens mount, default with 4mm focal length HD lens
  • 1W Small Speaker
  • Three-way Dial Button
  • 2.8” LCD with resistive touch screen, resolution 320*240
  • Dimension: 90x 61.5x9.5mm/3.54x2.42x0.37” (installed)
  • Maix GO Size: 60x 88mm/2.36x3.46”
  • Input Voltage: 4.8~5.2 V
  • Input Current: >600mA
  • Temperature Rise: <30 K
  • Operating Temperature: -30~85 ºC
  • Wireless Standard: 802.11 b/g/n
  • Frequency Range: 2400Mhz~2483.5Mhz
  • TX Power: 802.11.b : +15dBm
                        802.11.g : +10dBm(54Mbps)
                        802.11.n : +10dBm (65Mbps)
  • Antenna Connector: IPEX 3.03.0mm
  • WiFi Mode: Station/SoftAP/SoftAP+Station
  • Maix Go Development Board x1
  • Acrylic Case x1
  • 200 W Pixel M12 Camera (4mm focal length HD Lens) x1
  • 500mAH Lithium battery x1
  • 2.8”OVGA LCD x1
  • 1W Small Speaker x1
  • Type-C High Quality USB Cable x1
  • WiFi Antenna x1
