AI Module‑M1 is a compact embedded AI computing module built around the Kendryte K210 processor, designed for edge intelligence tasks such as computer vision, audio processing, and neural network inference. This AI development board integrates a dual‑core 64‑bit RISC‑V CPU with independent FPU, 8MB on‑chip SRAM, and a configurable operating frequency up to 400MHz. Compared with conventional CPU or GPU solutions, this embedded deep‑learning processor delivers higher inference efficiency, lower latency, and significantly reduced power consumption. Integrated neural network acceleration and signal‑processing hardware make this compact AI computing platform suitable for real‑time machine vision, voice recognition, and intelligent IoT deployments.
Note: Lead time of this product is unknown, sorry for the inconvenience.
K210 Edge AI Processor with Hardware Neural Acceleration
This AI computing module adopts the Kendryte K210 chip featuring dual 64‑bit RISC‑V cores with independent floating‑point units and an adjustable frequency reaching 400MHz. Integrated KPU neural network hardware acceleration enables efficient execution of convolution, batch normalization, activation, and pooling operations used in modern deep learning models. Compared with software‑based inference on standard processors, this edge AI processor delivers faster computation and improved energy efficiency, making the compact board suitable for embedded vision analysis, pattern recognition, and intelligent automation applications.
Real‑Time Vision Processing for Embedded Systems
This machine‑vision development module supports real‑time image recognition with performance up to QVGA at 60 frames per second or VGA at 30 frames per second. A dedicated digital video port supports image input up to 640×480 resolution, enabling efficient deployment of object recognition, gesture detection, and visual tracking algorithms. Hardware acceleration within the AI processing pipeline allows convolutional neural networks to operate directly on captured image data, making this vision AI board suitable for robotics perception systems and intelligent camera projects.
Integrated Audio Processing and Voice Analysis
An onboard audio processing unit supports advanced voice signal analysis alongside visual AI tasks. The embedded audio subsystem handles up to eight channels of audio input, equivalent to four stereo channels, while supporting multiple input data widths including 12‑bit, 16‑bit, 24‑bit, and 32‑bit formats. Internal 16‑bit audio signal processing combined with sampling rates up to 192kHz enables high‑quality sound acquisition and processing. This capability allows the compact AI board to perform tasks such as voice direction detection, acoustic event recognition, and intelligent voice interfaces.
Flexible IO Mapping and High‑Speed Memory Architecture
This AI edge computing board includes a programmable FPIOA (Field‑Programmable IO Array) capable of mapping up to 255 internal functions onto 48 external IO pins. Such flexibility allows developers to configure communication interfaces and peripherals according to project requirements. The onboard memory architecture divides 8MB SRAM into 6MB general‑purpose memory and 2MB dedicated AI SRAM, optimizing both neural network workloads and general computation. Additional hardware accelerators such as FFT units further enhance signal processing performance for embedded AI applications.
Figure: M1 AI+IoT Module K210 Deep learning
This compact AI computing module serves as a versatile platform for intelligent embedded systems including machine vision devices, voice‑controlled electronics, robotics perception modules, and smart IoT terminals. High‑performance neural processing combined with flexible peripheral interfaces allows rapid deployment of edge AI solutions in research, prototyping, and industrial automation environments.
