Maix Bit AI Development Board RISC-V K210 IoT
$20.90
SKU: DFR0639
AI development board with RISC-V chip, dual-core processor, 64-bit CPU, 8MB SRAM, MicroPython support, camera interfaces, and AI algorithm compatibility.
Purchase this product and earn 209 reward points, which are tied to VIP membership program. Learn More >
Maix Bit AI development board adopts AI chip K210 of RISC-V kernel. K210 comes with dual-core processor chip with independent FPU, 64 bits CPU bit width, 8 MB on-chip SRAM, 400 adjustable nominal frequency, and double precision FPU supporting multiplication, division, and square root operation.
On the 53.3mm x 25.4mm board, Maix Bit AI development board integrates on-board 128 Mbit high speed and large-capacity Flash, high speed USB to Serial port chip CH552, RGB LED, MEMS microphone, 24pin DVP camera interface, 24 pin 8bit MCU LCD interface. The product features RISC frame, high performance, low price, AI, and MicroPython support.
MaixPy firmware is micropython firmware, which makes it easy for everyone to use AI algorithms and the operation of conventional microcontrollers; MaixPy firmware is compatible with most APIs of OpenMV! Buying the MAIX development board is equivalent to having an OpenMV development board that is three times the price of the MAIX development board! And the measured power of the ordinary algorithm is 2~3 times of the original STM32H7 version! The power of the AI algorithm is even more than 1000 times that of the STM32H7 version of openmv! That's right, it's 1000 times!
  • Controller Chip: K210
  • Chip Kernel: dual-core RISC-V 64 bit IMAFDC
  • Main Frequency: nominal 400M, can be overclocked to 600M
  • Memory: 6MB general purpose memory+2MB AI memory
  • Flash: 16MB
  • Support MicroPython
  • Compatible with most OpenMV algorithms
  • Support Neural network algorithm: encapsulates the nnn class of mpy
  • Neural network algorithm speed: hundreds of GOPS (thousands of times STM32)
  • Face detection speed: conventional algorithms 6 frames
  • OVGA, RGB image: AI acceleration can reach more than 60 frames
  • Debugging support: UART and JTAG interface
  • GPIO Interface: all GPIOs connected to header 2.54mm
  • DVP Camera Connector: 24P 0.5mm FPC connector (compatible with OV2640, OV7740, OV5640, etc. )
  • LCD Connector: 8 bit MCU LCD 24P 0.5mm FPC connector
  • On-board MEMS Microphone
  • On-board TF Card Slot
  • Dimension: 53.3 25.4mm/2.101”
  • Input Voltage: 4.8~5.2 V
  • Input Current: >600mA
  • Temperature Rise: <30 K
  • Operating Temperature Range: -30~85 ºC
  • Maix Bit AI Development Board x1
  • Only 11 Left
