Cooling Case for NVIDIA Jetson Nano B01
$29.90
SKU: FIT0655
  • $29.00 3+ items
  • $28.40 5+ items
  • $27.50 10+ items
The cooling case for Jetson Nano includes dual fans, antenna holes, and a camera holder, with honeycomb vents for heat reduction and anti-skid pads for stability.
Is your NVIDIA Jetson Nano too hot and overheating? Don’t worry, here comes the cooling solution! This cooling case, with a reset switch and a blue backlit power button, is an efficient thermal solution customized for Jetson Nano. It includes two fans, one is pre-installed inside the case, the other is a PWM controllable fan for cooling the CPU.
Cooling Case for Jetson Nano B01
The case comes with two antenna holes and a camera holder for installing antenna and official Raspberry camera.
Honeycomb vents of the case reduce the heat generated by your device while it is performing neural network training or running machine vision programs. There are four anti-skid rubber pads on the bottom of the case to prevent skidding.
We provide you with anti-static tweezers and screwdriver to help you to install easily; besides, we offer you three jumper caps to ensure the normal operation of reset and restart functions.
Note:
1. Raspberry Camera and antenna are not included.
2. This case is suitable for Jetson Nano B01, please check the version of your Jetson Nano before ordering.
  • Dimension: 118*84*69mm/4.65*3.31*2.72”
  • Material: aluminium
  • Body Case with Fan x1
  • Speed Controllable Fan x1
  • Reset Switch with Jumper x1
  • 5V Power Button with Jumper x1
  • FC mode button x1
  • Camera Holder x2
  • Specification x1
  • Cooling Case for NVIDIA Jetson Nano B01
