DS3231M MEMS Precise RTC Breakout Board is a high‑reliability real‑time clock module built around the DS3231M chip, integrating a MEMS resonator and temperature compensation technology for stable timekeeping. Compared with traditional quartz crystal clocks, this MEMS-based timing solution significantly reduces risks associated with mechanical crystal failure, making the breakout board suitable for systems exposed to shock or vibration. The precision timing module maintains ±5ppm accuracy (±0.432 s/day) across a wide temperature range from -45°C to +85°C. Integrated calendar and clock functions deliver full time data including seconds, minutes, hours, days, months, and years through a compact I2C interface.
Note: According to the latest Air Transport Regulations, transportation of batteries, magnets, and liquids has become more restricted. Therefore, the CR1220 coin cell battery is no longer included with the module and should be purchased locally.
MEMS Resonator for Superior Mechanical Reliability
Unlike conventional RTC circuits that rely on fragile quartz crystals, this precision clock board integrates a MEMS resonator directly within the DS3231M chip. The solid-state MEMS timing structure improves durability and dramatically lowers the chance of mechanical failure. Such architecture enables dependable operation in environments involving vibration, motion, or mechanical shock, making the compact timing module appropriate for robotics systems, industrial equipment, and mobile electronics where crystal oscillators may suffer instability.
Automotive‑Grade Shock and Vibration Resistance
The MEMS-based RTC solution has passed shock and vibration qualification aligned with AEC‑Q100 related test conditions. The embedded clock system withstands mechanical shocks up to 2900g (JESD22‑B104C Condition‑H) and variable frequency vibration up to 20g (JESD22‑B103B Condition‑1). Such resilience allows the real‑time clock board to maintain stable timekeeping in harsh operating conditions including robotics platforms, moving vehicles, or portable instrumentation exposed to frequent mechanical stress.
High‑Accuracy Temperature‑Compensated Timing
Integrated temperature compensation ensures stable clock performance across a wide environmental range. The MEMS RTC module achieves ±5ppm timing accuracy (±0.432 seconds per day) from -45°C to +85°C, maintaining reliable time synchronization for embedded systems. Built‑in calendar logic automatically handles end‑of‑month adjustments and leap‑year corrections. Two programmable calendar alarms and a 1Hz square‑wave output enable precise scheduling and timing control for microcontroller applications.
Battery Backup and System Reset Support
A coin‑cell battery interface enables the timing circuit to continue operating during external power interruptions, preserving accurate time data even when the main system supply is disconnected. Calendar information including seconds, minutes, hours, day, month, and year remains continuously updated. An additional RST monitoring pin supports microprocessor reset functionality, allowing the RTC breakout board to serve both as a precise timekeeper and a system supervision component in embedded electronics.
Reliable timing performance, vibration tolerance, and integrated alarm features make this MEMS RTC breakout board suitable for data loggers, robotics controllers, industrial monitoring systems, and portable electronics. The compact I2C real‑time clock module integrates easily with embedded platforms while maintaining accurate timekeeping even during power loss or under harsh environmental conditions.
RTC Module Selection Guide
