6xAA Battery Holder(double layer)
$1.25
SKU: FIT0078
  • $1.15 2+ items
  • $1.05 3+ items
  • $0.95 5+ items
This battery holder accommodates 6 AA batteries, creating a 7.2V rechargeable pack or a 9V pack from alkaline cells, with included wires for easy connection.
Purchase this product and earn 13 reward points, which are tied to VIP membership program. Learn More >
6xAA Battery Holder (Double Layer) provides a compact solution for assembling higher-voltage battery packs using standard AA cells. This dual-layer AA battery case accommodates six batteries to create either a 7.2V rechargeable pack when paired with NiMH or NiCd cells, or a 9V battery pack using alkaline cells. Designed for electronics prototyping and portable hardware projects, the power holder integrates pre-attached red and black leads for straightforward connection to development boards, embedded controllers, and small robotic systems. The stacked enclosure structure keeps batteries organized while maintaining a compact footprint suitable for DIY electronics builds and educational hardware platforms.
Flexible Voltage Configuration with Standard AA Cells
This six-cell battery pack holder enables flexible voltage output depending on the battery chemistry used. NiMH or NiCd rechargeable AA cells combine to produce a 7.2V rechargeable pack suitable for robotics prototypes and portable electronics. When alkaline batteries are installed, the same holder forms a 9V battery pack for higher-voltage requirements. This adaptable battery enclosure simplifies power design for experimental circuits, sensor nodes, and controller-based projects by allowing common AA cells to serve as the primary energy source.
Compact Double-Layer Structure with Pre-Wired Leads
A stacked double-layer battery compartment keeps six AA cells securely arranged while reducing overall footprint compared with single-row holders. Integrated 6‑inch red and black wires provide convenient polarity identification and direct electrical connection to external circuits or power distribution modules. Side-by-side stack wiring simplifies integration with breadboards, embedded control boards, and prototype power systems. This practical design helps streamline wiring while maintaining reliable electrical contact between cells and connected electronics.
This multi‑cell AA battery enclosure supports a wide range of portable electronics builds, from robotics and embedded development boards to DIY instruments and classroom experiment kits. Reliable battery retention and pre-attached leads allow rapid integration into prototyping workflows, making the holder a practical power solution for mobile devices, testing platforms, and educational electronics assemblies.
  • Holds 6 AA batteries in a compact double-layer arrangement
  • Supports 7.2V packs using NiMH/NiCd cells or 9V packs using alkaline cells
  • Integrated 6-inch red and black power leads for easy circuit connection
  • Stacked battery structure reduces footprint for compact electronics projects
  • Suitable for prototyping, robotics, and portable electronic devices
  • Robotics power supply packs
  • Portable electronics prototypes
  • DIY electronic instruments
  • Educational electronics experiments
  • Embedded controller power systems
    Basic Parameters
  • Cell Quantity: 6
  • Battery type: AA
  • Storage temperature: 25'C (77F, RoomTemperature)
  • Max Operate temperature: 80'C (176F)
  • 6xAA battery holder (double layer) x1
  • 6xAA Battery Holder(double layer)
