Extension Cable For Raspberry Pi Camera
$1.90
SKU: FIT0672
  • $1.85 3+ items
  • $1.80 5+ items
  • $1.70 10+ items
30cm 15Pin FFC Ribbon cable for Raspberry Pi cameras, durable, easy to install, bendable without damage, and ensures smooth image/video transmission.
Purchase this product and earn 19 reward points, which are tied to VIP membership program. Learn More >
This a 30cm 15Pin FFC flat flex Ribbon cable for Raspberry Pi camera module. It features high quality, easy to install and durable in use.
The cable can be randomly bent without causing damage. There are insulated pads on the back that can closely contact with FPC seat to ensure the fluency of image and video transmission. The extension cable can be combined with Raspberry Pi camera cable to give you as much range as you’ll need.
Extension Cable For Raspberry Pi Extension Cable For Raspberry Pi
  • Connector: 15PIN
  • Length: 30cm
  • Compatible with all sorts of Raspberry Pi camera modules.
  • Extension Cable For Raspberry Pi x1
  • Review
    Ron. Feb 04, 2021
    These cables work well. I use them to provide more distance between a Raspberry Pi 4B and the DFRobot 5" touch display.
