This 9g servo for Maqueen Mechanic adopts high-quality metal gear, metal servo connecting plate, and four M3 threaded holes, convenient to install and easy to use.
It supports 0~180° rotation, and since there is no limit switch inside the servo, users can manually make it rotate in 360 degrees. This servo allows your Maqueen Plus to move smoothly, and never get stuck.
