10.1" 800x1280 mini-HDMI IPS Display (Compatible with Raspberry Pi & LattePanda Alpha) (Discontinued)
SKU: DFR0615
Discontinued
Note: 10.1" 800x1280 mini-HDMI IPS Display is discontinued now.
Since the supplier has stopped supplying raw materials of the products, we must inform you that 10.1 "800x1280 Mini HDMI IPS HD screen has been discontinued due to the inability to complete the production preparation. We are deeply sorry for the inconvenience and impact caused to you.
The display is not compatible with LattePanda V1 & LattePanda Delta.
This is a 10.1" mini-HDMI IPS Display with 800 × 1280 resolution. It supports mini-HDMI video signal input and microUSB power supply. It only requires 500mA to light up the screen and you can adjust the backlight brightness through the USB port. It supports 100-level backlight adjustment, you can use script to control the brightness. The screen supports three major operating systems such as Linux, Windows, and MACOS, especially the Raspberry Pi. It works directly with Raspberry Pi, LattePanda Alpha, and other devices with HDMI output, which can basically achieve full platform compatibility.
Remark:
  • This is a vertical screen. Linux systems such as Raspberry Pi can rotate the screen through the config.txt configuration file. The configuration file is shown below. When the Windows system is used in the first time, please rotate the screen angle in the system.
  • When using the Raspberry Pi to supply power the screen, you need to ensure that the Raspberry Pi has sufficient power supply capacity. The screen will consume about 0.5A@5V of current, so please pay attention to the power supply output of the wall adapter. You must still ensure the The Raspberry Pi works stably.
  • The screen's micro-USB port and mini-HDMI port must be connected to the same device to ensure that the signals share the same GND, otherwise problems such as splash screens will occur.
  • 10.1" HDMI Display with 800x1280 Resolution (WXGA)
  • Cost-effective IPS Display, compatible with Raspberry Pi and LattePanda Alpha
  • 5V@500mA USB Power Supply, no external power device required
  • Windows/Linux/MacOS Multi-system Support
  • 0~100 Classification Brightness Control
    • Screen Size: 10.1 "
    • Screen Resolution: 800 × 1280 (WXVGA)
    • Video Signal Interface: Mini-HDMI
    • Screen Color: 16.7M colors
    • Brightness: 200cd / m2 (support 0 ~ 100 classification)
    • Working Current: 5V @ 500mA (micro-USB)
    • Screen: 16.7M colors
    • Support System: Linux / Windows / MacOS
    • Screen Size: 245mm × 160mm × 9mm
    • Display Area: 135.36mm × 216.68mm
    • 10.1" 800x1280 mini-HDMI IPS Display x1
    • Mini-HDMI to HDMI cable x1
    • Mini-HDMI to Micro-HDMI cable x1
    • Micro-USB cable x1
    trevor.blum Oct 31, 2020
    This monitor took me a little while to understand. It is not a standard resolution and requires the specific custom config.txt that DFRobot publish. On the Raspberry Pi4, at this time, I could only use it as a single screen. I could not find a way to set up two different resolution monitors when the DFR0615 custom config.txt was used even with [HDMI:0] and {HDMI:1] sections. Interestingly, the DFR0615 works with PiZero, so I can now use more of them generally.
