Discontinued
Note: 10.1" 800x1280 mini-HDMI IPS Display is discontinued now.
Since the supplier has stopped supplying raw materials of the products, we must inform you that 10.1 "800x1280 Mini HDMI IPS HD screen has been discontinued due to the inability to complete the production preparation. We are deeply sorry for the inconvenience and impact caused to you.
The display is not compatible with LattePanda V1 & LattePanda Delta.
This is a 10.1" mini-HDMI IPS Display with 800 × 1280 resolution. It supports mini-HDMI video signal input and microUSB power supply. It only requires 500mA to light up the screen and you can adjust the backlight brightness through the USB port. It supports 100-level backlight adjustment, you can use script to control the brightness. The screen supports three major operating systems such as Linux, Windows, and MACOS, especially the Raspberry Pi. It works directly with Raspberry Pi, LattePanda Alpha, and other devices with HDMI output, which can basically achieve full platform compatibility.
Remark:
Oct 31, 2020
This monitor took me a little while to understand. It is not a standard resolution and requires the specific custom config.txt that DFRobot publish. On the Raspberry Pi4, at this time, I could only use it as a single screen. I could not find a way to set up two different resolution monitors when the DFR0615 custom config.txt was used even with [HDMI:0] and {HDMI:1] sections. Interestingly, the DFR0615 works with PiZero, so I can now use more of them generally.
