This 2.0” LCD display adopts ST7789V driver chip and has 320*240 color pixels (RGB565), performing excellently in the angle of view (80/80/80/80). It supports SPI(4-wire) communication mode and GDI port (work with main-controllers with GDI), plug, and play. The module can be powered by 3.3V~5V, compatible with multiple main-controllers like Arduino UNO, Leonardo, ESP32, ESP8266, FireBeetle M0, and so on. Use the GDI interface to work with M0, which could effectively reduce wiring steps. Besides, there is an onboard MicroSD card slot for displaying more pictures.
The module has the advantages of high resolution, wide viewing angle, and simple wiring, and can be used in many display applications: waveform monitor display, electronic gift box, electronic weather decorations, etc.
NOTE: MicroSD Card is not included, click here to buy one.
May 15, 2026
not too complicated to solder and connect to my espressif esp 32 devkitC great colors and quality tbh
Mar 26, 2026
Great display. Its bright and clean. I really like the GDI ribbon cable that compliments the ESP32's that DF has with the GDI. I do prefer using the Adafruit_ST7789 library. If you have issues with the SD card reader it is most likely your SD card. I used some cheap ones from amazon and they didn't always initialize.
Nov 07, 2025
Excellent small IPS display! The colors are bright and the viewing angles are great. Easy to use with ESP32 or Arduino boards. The built-in MicroSD card slot is very convenient for images or data storage. I used it in an IoT project and it worked perfectly. Great value for money — highly recommended!
