If you have both a Type-C interface device and a Micro USB interface device and you need to bring two cables, it will be very troublesome. Therefore, we specially customized the Type-C&Micro 2-in-1 USB Cable. The flat cable is not easy to knot, and the upper silicone cable tie is convenient for storage, this USB cable can upload programs, and one wire can solve a variety of board usage problems.
Note: The order of the Type-C and MicroUSB connectors may vary, but the functionality is identical.
