Metal Heatsink Case for Raspberry Pi 4 provides an integrated thermal management enclosure designed to protect and cool high‑performance single‑board computers. Constructed from aluminum alloy, the enclosure functions as both a structural protective shell and a passive heat spreader. A silicone thermal pad transfers heat from the processor to the metal housing, while an integrated cooling fan accelerates airflow to remove accumulated heat. This compact cooling enclosure improves thermal stability during intensive workloads such as media processing, edge computing, and embedded development using Raspberry Pi platforms.
Aluminum Alloy Heat Dissipation Structure
The aluminum alloy enclosure operates as a full‑body heat sink, allowing generated heat to spread efficiently across the metal surface. Compared with plastic housings, the metal chassis significantly improves thermal conductivity and passive cooling efficiency. This protective computing enclosure also shields the single‑board computer from physical damage while maintaining stable temperatures during extended processing loads. The durable metal structure therefore combines mechanical protection with enhanced heat dispersion for long‑term system reliability.
Figure: Aluminum alloy enclosure design
Precision Port Alignment
Carefully machined openings align precisely with the ports and connectors of the embedded computing board. Accurate hole positioning ensures full access to USB, HDMI, power, and network interfaces without interference. This precise mechanical design prevents stress or accidental damage during installation or removal, enabling reliable integration into development projects, embedded prototypes, or compact computing systems that require unobstructed connectivity.
Figure: Precision aligned interface openings
Slide‑Open Structure for Quick Assembly
A removable upper and lower cover design allows the enclosure to slide open smoothly, simplifying installation and maintenance. The modular mechanical structure enables hardware replacement or upgrades without removing the entire mainboard assembly. This convenient assembly mechanism reduces installation time while maintaining structural stability, making the enclosure suitable for frequent prototyping cycles, system upgrades, or hardware debugging in embedded development environments.
Figure: Slide‑open enclosure structure
Active and Passive Dual Cooling System
A silicone thermal pad directly contacts the processor and transfers heat to the aluminum radiator shell. The integrated DC 5V fan then drives airflow across the enclosure to accelerate heat dissipation. This combination of passive conduction and active airflow creates a complete internal‑to‑external cooling path, ensuring stable thermal performance during heavy workloads such as server applications, media centers, and edge computing deployments.
Figure: Active cooling fan and heatsink structure
Such a thermally optimized enclosure supports stable operation in embedded systems, media servers, robotics controllers, and edge computing nodes. The metal cooling chassis is particularly suitable for applications requiring sustained processing performance where efficient thermal control and mechanical protection are both essential.
Oct 27, 2020
good product and shipping thank you
