Firebeetle 2 M0 Development Board
$8.90
SKU: DFR0652
  • $8.60 3+ items
  • $8.50 5+ items
  • $8.20 10+ items
Compact development board featuring ATSAMD21G18 ARM Cortex M0+, 16MB SPI Flash, Type-C port, RGB LED, and multi-language support. Not compatible with previous versions.
FireBeetle is a product series of small development boards developed by DFRobot. It contains various chipboards and expansion boards that can be used alone or in combination. The same as Arduino M0, FireBeetle 2 M0 also adopts the high-performance low-power chip ATSAMD21G18 ARM Cortex M0+. With up to 48MHz frequency, it offers 32kb RAM and 256kb Flash, which is 8 times and 16 times of Atmega328 respectively. Designed with 16MB SPI Flash and a built-in 12MB flash drive, FireBeetle 2 M0 simplifies the data interaction between the user's desktop system and the board and supports SPI Flash-based easy flash database. Besides, the built-in SPI Flash-based word model allows users to directly display multi-language words, such as Chinese, British, Japanese, and Korean.
Firebeetle 2 Board-M0 (V1.0) adopts a convenient Type-C port and a more comfortable horizontal switch. The onboard WS2812 RGB indicator and FPC make the display much easier to use.
Note: FireBeetle 2 and FireBeetle pins and sizes are not compatible, and neither are the expansion boards.
  • Low Power Consumption
  • Small Size
  • Onboard FPC
  • Built-in U disk, database, word library based on SPI Flash
  • Input Voltage: 3.3V~5.5V
  • Supports Low Power Consumption: 30uA
  • Supports Maximum Charging Current: 300mA
  • Processor: ATSAMD21G18
  • SPI: 1
  • I2C: 1
  • UART: 2
  • RGB LED: WS2812
  • Interface Mode: FireBeetle V2 series compatible
  • Working Temperature: -40℃~+85℃
  • Dimension: 25.4×60(mm)/1.0×2.36”
  • Firebeetle 2 Board-M0(V1.0) Module x1
  • 18pin-2.54mm Pin Header x1
  • 18pin-2.54mm Female Header x1
  • 14pin-2.54mm Pin Header x1
  • 14pin-2.54mm Female Header x1
FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
Blog FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
Jun 08, 2025
Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
Blog Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
Sep 25, 2023
DIY an Audio Photo Album-Based on FireBeetle M0
Projects DIY an Audio Photo Album-Based on FireBeetle M0
Frances
Nov 07, 2024
The Millennium Falcon Audio Visualizer
Projects The Millennium Falcon Audio Visualizer
alankrantas
Feb 20, 2021
