10 Sets M3 * 10 Hexagonal Standoffs Mounting Kit
$2.50
SKU: FIT0063
  • $2.30 3+ items
  • $2.10 5+ items
  • $1.80 10+ items
10-pack hexagonal standoffs, suitable for circuit boards and robot chassis, includes screws and nuts. Length: 10mm, weight: 80g.
M3 x 10mm Hexagonal Standoff Mounting Kit provides a practical hardware solution for mechanically securing circuit boards, sensors, and structural components in electronics projects. This compact spacer set functions as reliable mechanical support between stacked boards, enabling stable vertical spacing and organized wiring. The hexagonal standoff hardware is commonly used when building layered robotic platforms, controller mounts, and sensor assemblies. Manufactured for M3 fasteners, the mounting kit simplifies board-to-board installation while maintaining consistent spacing, making the hardware suitable for prototyping environments, robotics builds, and general electronics assembly.
Reliable Mechanical Spacing for Electronics Assemblies
This hex standoff set creates a fixed 10mm spacing between structural layers, ensuring stable mounting of circuit boards and electronic modules. The rigid hexagonal spacer hardware prevents unwanted movement and helps maintain alignment between stacked PCBs, sensor brackets, and controller boards. Such mechanical separation improves airflow, reduces risk of short circuits, and allows organized cable routing inside compact builds. The durable threaded design supports repeated installation during development cycles, making the spacer kit suitable for robotics prototyping, experimental electronics, and multi-board system integration.
Complete Hardware Set for Fast Installation
This robotics chassis spacer kit includes matched screws and nuts designed to work with the M3 threaded standoffs, providing a convenient all-in-one mounting solution. The included fasteners allow secure attachment of circuit boards to the top of each spacer while maintaining structural stability across stacked layers. Such a configuration simplifies construction of multi-tier robot frames, controller mounts, and sensor platforms. The mechanical spacer hardware eliminates the need to source separate mounting components, streamlining assembly for electronics prototyping and small mechanical builds.
Compact mounting hardware such as this mechanical spacer set supports numerous electronics and robotics applications. Typical uses include multi-level robot chassis construction, stacked controller boards, sensor mounting brackets, and general circuit board spacing within experimental systems. Consistent 10mm separation and reliable threaded connections make the spacer kit well suited for prototyping benches, educational robotics platforms, and modular electronics structures.
  • M3 threaded hexagonal standoffs for secure PCB spacing
  • 10mm spacer length suitable for stacked circuit board assemblies
  • Includes matching screws and nuts for convenient installation
  • Hexagonal structure provides stable mechanical support
  • Suitable for robotics chassis, sensor mounts, and electronics prototyping
  • Multi-level robot chassis construction
  • Circuit board stacking and spacing
  • Sensor mounting structures
  • Electronics prototyping platforms
  • Mechanical support for embedded hardware assemblies
    Basic Parameters
  • Hexagonal standoffs mounting kit length: 10 mm (0.4 in)
  • Weight: 80g
  • M3 * 10 hexagonal standoffs x10
  • M3 * 6 screws x10
  • M3 nuts x10
  • 10 Sets M3 * 10 Hexagonal Standoffs Mounting Kit
