Armor Case With Dual Fans(2510) for Raspberry Pi 4
$17.90
SKU: FIT0715
Aluminum case for Raspberry Pi 4B with dual fans and thermal pads for cooling. It has an acrylic side for better wireless signal and access to ports.
Rigid Armor protective case with super heat dissipation!
This new aluminum case is capable of providing a better cooling solution for your Raspberry Pi 4B. Meanwhile, it can be access to all ports and slots of Pi 4B module.
Armor Case With Dual Fans(2510) for Pi 4
The thermal pads cover all the heat-generating components except the wireless chip. And they align with the heat sink perfectly to achieve better heat dissipation.
The dual fans can provide a much better cooling effect for Pi 4 board while still can work very quietly.
This case has an acrylic window on the side that helps in improving Wi-Fi/Bluetooth performance and makes status lights visible. It also provides Micro-SD card access and camera cable pass-through.
  • Rigid armor case
  • Aluminum body
  • Acrylic side plate for better wireless signal strength
  • Easy to install
  • Fan Speed: 7500 rpm
  • Compatible with Raspberry Pi 4B
  • Dimension: 10.8 x 7.6 x 3.8cm
  • Weight: 200g
  • Armor Case With Dual Fans(2510) for Pi 4 x1
  • User Manual x1
  • Only 13 Left
