Rigid Armor protective case with super heat dissipation!
This new aluminum case is capable of providing a better cooling solution for your Raspberry Pi 4B. Meanwhile, it can be access to all ports and slots of Pi 4B module.
The thermal pads cover all the heat-generating components except the wireless chip. And they align with the heat sink perfectly to achieve better heat dissipation.
The dual fans can provide a much better cooling effect for Pi 4 board while still can work very quietly.
This case has an acrylic window on the side that helps in improving Wi-Fi/Bluetooth performance and makes status lights visible. It also provides Micro-SD card access and camera cable pass-through.
