This NEO case is designed specifically for the needs and functionality of the Raspberry Pi 4 Model B. Made with aluminum alloy and polished with a modem Space Grey finish for stunning aesthetics.
The case acts as passive cooling for the high demands of the Raspberry Pi 4 Model B. The hollow design on the bottom of the case also could improve the cooling effect a lot.
The case has a magnetic top to keep the ports safe when not in use. The main-board can be closely contacted with the case. All ports of the Pi4 are reserved and there is a camera port on the case for fixing Pi camera, more convenient to use.
