USB 2.0 Type‑A to Mini‑USB 5‑Pin Cable provides reliable connectivity for compact development boards and portable electronics that rely on the classic Mini‑USB interface. This compact data and power cable links computers, chargers, and USB hubs with embedded hardware platforms requiring Mini‑USB communication. Designed for dependable data transfer and stable power delivery, this connection cable supports firmware uploading, serial communication, and device powering in maker and engineering workflows. Compatibility includes development platforms such as the DFRduino Nano and arduino FIO, along with many handheld electronics and legacy Mini‑USB devices.
Reliable USB 2.0 Data and Power Connectivity
This USB data cable supports standard USB 2.0 communication for dependable data transfer between computers and Mini‑USB embedded hardware. Stable signal transmission enables smooth firmware uploads, serial debugging, and device communication during development workflows. The Mini‑USB 5‑pin connector ensures consistent electrical contact for both power delivery and data exchange, making this connection accessory suitable for development boards, portable electronics, and compact digital devices that rely on legacy Mini‑USB interfaces.
Compact Interface for Embedded Development Hardware
Mini‑USB connectors are widely used across earlier generations of compact electronics and maker hardware due to their smaller physical profile compared with traditional USB connectors. This USB Type‑A to Mini‑USB cable integrates seamlessly with development boards, handheld devices, and portable modules that utilize the Mini‑USB port format. Reliable mechanical fit and simple plug‑and‑play operation make this cable a practical accessory for prototyping environments, electronics laboratories, and embedded development setups.
Within electronics prototyping, this Mini‑USB connection cable supports development boards, portable controllers, and legacy embedded modules requiring USB programming or power supply. Typical uses include firmware uploading, serial communication, charging small devices, and connecting maker hardware to computers during development and testing. The compact interface makes this accessory well suited for educational labs, robotics prototyping, and general embedded electronics development.
Basic Parameters
Compatibility
