Raspberry Pi Compute Module 4 Antenna Kit (Discontinued)
SKU: FIT0735
Discontinued
Note: Raspberry Pi Compute Module 4 Antenna Kit is discontinued now. If you need the latest Raspberry Pi SBC, please click Raspberry Pi 5 Single Board Computer.
This Antenna Kit is certified for use with the Raspberry Pi Compute Module 4. If a different antenna is used, then separate certification will be required, and this must be arranged by the end-product design engineer.
Fitting instructions
1.Connect the U.FL connector on the cable to the U.FL-compatible connector on Compute Module 4
2.Screw the toothed washer onto the SMA (male) connector on the cable, then insert this SMA connector through a hole (e.g. 6.4 mm) in the end-product mounting panel
3.Screw the SMA connector into place with the retaining hexagonal nut and washer
4.Screw the SMA (female) connector on the antenna onto the SMA (male) connector which now protrudes through the mounting panel
5.Adjust the antenna to its final position by turning it through up to 90°, as shown in the illustration below.
Raspberry Pi Compute Module 4 Antenna Kit Fitting instructions
Dimension
Raspberry Pi Compute Module 4 Antenna Kit Dimension
Antenna
  • Model number: YH2400-5800-SMA-108
  • Frequency range: 2400-2500/5100-5800 MHz
  • Bandwidth: 100–700MHz
  • VSWR: ≤ 2.0
  • Gain: 2 dBi
  • Impedance: 50 ohm
  • Polarisation: Vertical
  • Radiation: Omnidirectional
  • Maximum power: 10W
  • Connector: SMA (female)
  • Dimensions: 108 mm × 10 mm
  • Shell material: ABS
  • Installation: Screw
  • Operating temperature: -35 to +75°C
  • Weight: ± 3 g
SMA to U.FL Cable
  • Model number: HD0052-09-A01_A0897-1101
  • Frequency range: 0–6GHz
  • Impedance: 50 ohm
  • VSWR: ≤ 1.4
  • Connector (to antenna): SMA (male)
  • Connector (to CM4): U.FL
  • Dimensions: 205 mm × 1.37 mm (cable diameter)
  • Operating temperature: -45 to +80°C
  • Raspberry Pi Compute Module 4 Antenna Kit x1
