Waterproof Cable Gland PG7L (Gray) provides a reliable sealing solution for cables entering outdoor or moisture‑sensitive electronic enclosures. Drilling holes in project boxes often introduces a path for rain, condensation, or splash water to reach internal circuitry. This compact cable sealing component addresses that vulnerability by creating a tight compression seal around passing wires. Designed for cables ranging from 0.118–0.169" (3–6.5mm), the PG7L gland offers dependable strain relief and environmental protection for electronics projects, industrial control boxes, sensor housings, and DIY hardware installations that require durable cable routing through waterproof enclosures.
Figure: Waterproof Cable Gland PG7L Size(gray)
IP68 Waterproof Sealing
An integrated sealing gasket and compression structure deliver IP68-rated waterproof performance, forming a tight barrier between the cable and enclosure wall. This weather‑resistant cable entry fitting protects internal electronics from rain, splashes, dust, and moisture intrusion. Such protection is especially valuable for outdoor IoT installations, environmental monitoring equipment, robotics housings, and industrial control boxes exposed to harsh environments.
Secure Cable Clamping and Strain Relief
The PG7L cable gland firmly grips wires within the supported diameter range of 3–6.5mm (0.118–0.169"). The internal compression structure stabilizes the cable and reduces mechanical stress on connectors or internal wiring. This strain‑relief function helps maintain reliable electrical connections while preventing cable loosening caused by vibration, movement, or repeated handling in field deployments.
Compact Hardware for Enclosure Integration
A lightweight 6.2g construction and compact PG7 form factor allow convenient installation in small electronics enclosures or sensor housings. This cable entry accessory integrates easily into DIY electronics boxes, robotics systems, and outdoor instrumentation assemblies. The design simplifies cable routing through sealed panels while maintaining enclosure integrity and professional cable management.
Such waterproof cable management hardware suits outdoor electronics builds, weatherproof sensor stations, robotics platforms, and industrial control enclosures where reliable sealing around cable entry points remains essential.
