This fast-charging module comes with both USB and Type-C ports, supporting 10.5-32V voltage input and 5V/3A output, and multiple charging protocols.
With steady output, this Fast Charge Module is able to work for a long time without voltage shift. It can be suitable for projects like mobile phone fast charging, Car charging retrofit, solar charger, DIY power source, etc.
Note: The power pins of Type-C and USB output are in parallel, so the two output ports should not be used simultaneously, otherwise, the module may be damaged.
