DC-DC Fast Charge Module 10.5~32V to 5V3A
$6.50
SKU: DFR0758
  • $6.30 3+ items
  • $6.20 5+ items
  • $5.90 10+ items
Fast charging module with USB and Type-C ports, supports 10.5-32V input, 5V/3A output, multiple protocols. Avoid using both ports simultaneously.
Purchase this product and earn 65 reward points, which are tied to VIP membership program. Learn More >
This fast-charging module comes with both USB and Type-C ports, supporting 10.5-32V voltage input and 5V/3A output, and multiple charging protocols.
With steady output, this Fast Charge Module is able to work for a long time without voltage shift. It can be suitable for projects like mobile phone fast charging, Car charging retrofit, solar charger, DIY power source, etc.
 Note:  The power pins of Type-C and USB output are in parallel, so the two output ports should not be used simultaneously, otherwise, the module may be damaged.
  • Dual output ports
  • Support for multiple fast-charging protocols
  • Can be used as a charging module or power supply
  • Input Voltage Range: 10.5V-32V
  • Output Voltage Range: 3-20V Auto-adjust based on fast-charging protocol (Default output 5V, the input should be 2V higher than the output)
  • Output Current: 0-3A
  • Input Port: DC5.5*2.1mm
  • Output Port: common USB+Type-C
  • Chip Protection: input overvoltage, undervoltage protection, output overcurrent, overvoltage, undervoltage, short circuit protection
  • Supported Fast Charging Protocol:
        BC1.2, Apple, Samsung
        Qualcomm QC2.0 and 3.0
        MTK PE+1.1 and MTK PF+2.0
        Huawei fast charging protocol FCP/SCP
        Samsung fast charging protocol AFC
        supports spreadtrum fast charge protocol SFCP
  • DC-DC Fast Charge Module 10.5~32V to 5V3A x1
  • Only 14 Left
