Gravity: I2C HUB
$1.50
SKU: DFR0759
  • $1.45 3+ items
  • $1.43 5+ items
  • $1.40 10+ items
Connects up to 8 I2C devices to a controller. Includes sensor cable. Dimensions: 27x37mm, weight: 17g. Provides links to projects and documentation.
Purchase this product and earn 15 reward points, which are tied to VIP membership program. Learn More >
This Gravity: I2C HUB module is designed to connect up to 8 I2C devices to a main-controller, which allows you easily to hook up multiple I2C devices in project building, for instance, use Gravity-4P I2C/UART sensor cable to connect with Gravity modules or use Jumper Wire to connect with Breakout modules.
  • PCB dimensions: 37mm × 27mm
  • Mounting hole spacing: 30mm × 20mm
  • Mounting hole diameter: 3.1mm
  • Weight: 17g
  • Gravity: I2C HUB     x1
  • Gravity-4P I2C/UART Sensor Cable  x1
Ultrasonic Air Drums
Projects Ultrasonic Air Drums
Bill.Kolicoski
Feb 24, 2023
Kaj Ronny.Nilsen Dec 08, 2025
This board is such a great help when testing the Pi Pico, highly recommended! Very easy to use with lots of pins.
Aunuun Jeffry.Mahbuubi Sep 20, 2025
Good service and fast shipping
Steffen.Lorenz Jan 30, 2025
Perfect device, nothing to complain about.
Gravity: I2C HUB
