This Gravity: I2C HUB module is designed to connect up to 8 I2C devices to a main-controller, which allows you easily to hook up multiple I2C devices in project building, for instance, use Gravity-4P I2C/UART sensor cable to connect with Gravity modules or use Jumper Wire to connect with Breakout modules.
Dec 08, 2025
This board is such a great help when testing the Pi Pico, highly recommended! Very easy to use with lots of pins.
Sep 20, 2025
Good service and fast shipping
Jan 30, 2025
Perfect device, nothing to complain about.
