High Power Bluetooth Power Amplifier Board
$15.00
SKU: DFR0777
  • $14.50 3+ items
  • $14.30 5+ items
  • $13.80 10+ items
This Bluetooth amplifier board offers 100W output, Bluetooth 5.0, and is compatible with 4-8Ω speakers. Features include volume control, protection, and DIY connectivity.
Purchase this product and earn 150 reward points, which are tied to VIP membership program. Learn More >
High Power Bluetooth Power Amplifier Board (100W×2) enables rapid development of custom wireless speaker systems and compact stereo audio projects. This high‑output Bluetooth amplifier module integrates Bluetooth 5.0 wireless audio input, dual‑channel stereo output, and a physical volume control knob on a compact board. Operating from a wide 5–24V DC supply, the audio amplification board supports 4–8Ω passive speakers rated between 50W and 300W. Wireless music streaming can be paired directly with mobile devices or embedded computers such as Raspberry Pi, making the module suitable for DIY speakers, multimedia terminals, and smart audio systems.
Note: Adequate output power requires sufficient audio input level and adequate power supply voltage/current. Higher supply voltage produces higher output power. Speaker impedance also influences amplifier performance; under sufficient voltage and current conditions, higher impedance speakers produce lower output power.
100W ×2 High‑Power Stereo Audio Amplification
This Bluetooth stereo amplifier module delivers up to 100W per channel, providing strong output capability for passive speaker systems. Dual‑track left and right channels support clear stereo sound reproduction, making the board suitable for bookshelf speakers, portable audio builds, and compact home audio installations. Compatibility with 4Ω–8Ω passive speakers rated between 50W and 300W allows flexible integration across different DIY speaker configurations and enclosure designs.
Stable Output with Robust Power Design
The wireless audio amplifier board integrates four high‑quality 470µF capacitors to stabilize the power stage and maintain consistent audio performance under load. A dedicated heat sink combined with an efficient power management module supports long‑term operation during high‑output playback. This design improves electrical stability, minimizes distortion during peak output, and helps maintain reliable operation in continuous music playback or multimedia systems.
Integrated Protection and Enclosure Support
The stereo Bluetooth amplifier includes automatic overheat protection and short‑circuit protection to safeguard connected speakers and power systems. Protective top and bottom acrylic panels provide mechanical shielding for electronic components while maintaining ventilation for thermal dissipation. Such protection mechanisms make the audio amplification board suitable for embedded electronics builds, DIY speaker cabinets, and educational audio hardware prototypes.
High Power Bluetooth Power Amplifier Board (100W*2)
Figure: High Power Bluetooth Power Amplifier Board (100W×2)
Typical applications include DIY wireless speakers, compact stereo audio systems, multimedia terminals, smart home audio devices, and embedded sound systems connected to SBC platforms or mobile Bluetooth sources.
  • Bluetooth 5.0 wireless audio input
  • High‑power stereo output up to 100W ×2
  • Wide operating voltage range: 5–24V DC
  • Supports 4Ω–8Ω passive speakers (50W–300W)
  • Integrated volume control knob
  • Four 470µF capacitors for stable power output
  • Onboard heat sink for improved thermal performance
  • Automatic overheat protection
  • Automatic short‑circuit protection
  • Acrylic protective panels for mechanical protection
  • DIY wireless Bluetooth speakers
  • Compact home stereo systems
  • Raspberry Pi multimedia audio projects
  • Portable speaker builds
  • Embedded audio playback systems
  • Educational electronics audio demonstrations
  • Supply Voltage: 5-24V
  • Output Power: 100W*2
  • Compatible Speakers: 50W-300W, 4Ω-8Ω
  • Sound Channel: left/right channel(stereo audio)
  • Bluetooth Version: 5.0
  • Bluetooth Transmission Distance: 15m (without any obstacle)
  • Protection: auto overheat protection, auto short circuit protection
  • Power Source Voltage:
        12V -- 8Ω speaker / 24W (left channel) + 24W (right channel), 4Ω speaker / 40W + 40W
        15V -- 8Ω / 32W + 32W, 4Ω / >60W + 60W
        19V -- 8Ω / 64W + 64W, 4Ω / >80W + 80W
        24V -- 8Ω / 72W + 72W, 4Ω / >100W + 100W
  • High Power Bluetooth Power Amplifier Board x1
  • Acrylic Protective Case x2
  • Screwdriver x1
  • 20cm Power Wire x1
  • Knob x1
  • Accessories Package x1
Bluetooth Amplifier Board Selection Guide
Blog Bluetooth Amplifier Board Selection Guide
Feb 07, 2021
Only 9 Left
