Conductive Stainless Thread (30-40Ω)
$7.90
SKU: FIT0743
  • $7.80 3+ items
  • $7.50 5+ items
  • $7.20 10+ items
Conductive sewing thread made of stainless steel, offering low resistance, good thermal conductivity, and reusable for electronics. 25m roll, 30-40Ω/m.
Conductive Stainless Steel Sewing Thread provides a flexible electrical pathway for wearable electronics, textile-based circuits, and antistatic garments. Manufactured from fine stainless steel fibers, this conductive textile thread combines sewing flexibility with reliable electrical conductivity. The metallic fiber structure delivers stable resistance of 30–40Ω per meter while maintaining durability under bending and stitching. With a 0.3mm diameter and a total length of 25 meters per roll, this e‑textile wiring solution enables discreet circuit routing directly within fabrics. The stainless fiber construction also offers strong thermal tolerance, making the conductive sewing material suitable for experimental wearable designs, sensor textiles, and low-current electronic integrations.
Note: the thinner the wire, the more resistance it offers.
Figure: Conductive stainless steel sewing thread used for textile circuits and wearable electronics
Stable Conductivity for Textile Circuits
Stainless steel fiber construction delivers consistent electrical performance while retaining the flexibility required for sewing and embroidery. This conductive textile filament maintains a resistance range of 30–40Ω per meter, enabling reliable signal transmission and low-current power routing across fabric-based circuits. The smooth metallic fibers allow the thread to pass easily through fabric while maintaining electrical continuity, making the conductive sewing material suitable for connecting LEDs, sensors, and small electronic modules integrated directly into garments or soft wearable platforms.
High Temperature and Mechanical Durability
Engineered with stainless steel microfibers, this e‑textile conductive thread withstands demanding thermal conditions that would damage conventional conductive yarns. Operating tolerance reaches 650°C with a melting point of approximately 1350°C, ensuring structural stability in high‑temperature environments. The metal fiber structure also resists wear and deformation during repeated stitching or bending, supporting long‑term use in experimental textile electronics, industrial antistatic fabrics, and research prototypes requiring durable conductive pathways.
Washable and Reusable for Wearable Projects
Unlike fragile conductive coatings or printed circuits, this stainless fiber sewing thread maintains electrical functionality after washing and repeated use. The corrosion‑resistant metal composition supports integration into garments that require routine cleaning while preserving conductive performance. Such durability makes the textile conductor practical for wearable electronics, touchscreen gloves, antistatic clothing, and fabric‑based sensor systems where repeated movement, washing, and environmental exposure are common.
Typical uses include touchscreen-compatible gloves, antistatic clothing, wearable electronic prototypes, conductive embroidery, antistatic brushes, and low‑current LED circuits embedded into fabrics. The stainless steel conductive thread also supports experimental e‑textile development, educational wearable technology projects, and fabric-based sensing systems where flexible electrical routing inside textiles is required.
  • Low resistance and stable resistivity
  • High-temperature resistance 650°C, melting point 1350°C
  • Safe to wash, reusable
  • Touchscreen gloves
  • Anti-static clothing
  • Wearable electronic equipment
  • Conductive embroidery circuits
  • Anti-static brushes
  • Low-current LED connections in textiles
  • Wire Resistance: 30-40Ω/m
  • Length: 25m
  • Diameter: 0.3mm
  • Conductive Stainless Thread (30-40Ω) x1
Conductive Stainless Steel Sewing Thread Selection Guide
Blog Conductive Stainless Steel Sewing Thread Selection Guide
Feb 06, 2021
