ESP32-S2-DevKitM-1 Wi-Fi MCU Development Board
$18.00
SKU: DFR0813
  • $17.50 3+ items
  • $17.00 5+ items
  • $16.50 10+ items
Entry-level development board with ESP32-S2-MINI-1 Wi-Fi MCU, featuring a 4 MB SPI flash, USB-UART bridge, and versatile GPIO for various functions.
Purchase this product and earn 180 reward points, which are tied to VIP membership program. Learn More >
The ESP32-S2-DevKitM-1 is an entry-level development board featuring the ESP32-S2-MINI-1 module. This module integrates the ESP32-S2FH4 chip, which has a Xtensa® single-core 32-bit LX7 microprocessor, 128 KB ROM, and 320 KB SRAM. The board includes 4 MB of SPI flash and provides Wi-Fi (802.11 b/g/n) connectivity. All available GPIO pins are broken out to breadboard-compatible headers. It includes a USB-to-UART bridge for programming and power via a Micro-USB port. An addressable RGB LED (WS2812) is connected to GPIO18.
ESP32-S2-MINI-1 is a generic Wi-Fi MCU module that integrates ESP32-S2FH4 chip. ESP32-S2-MINI-1 comes with a PCB antenna and features a 4 MB SPI flash.
Description of Components
ESP32-S2-DevKitM-1 Development Board Description of Components
Key Component
Description
ESP32-S2-MINI-1
ESP32-S2-MINI-1 is a generic Wi-Fi MCU module that integrates ESP32-S2FH4 chip. ESP32-S2-MINI-1 comes with a PCB antenna. And the module features a 4 MB SPI flash.
3.3 V Power On LED
Turns on when the USB power is connected to the board.
USB to UART Bridge
Single USB-UART bridge chip provides transfer rates up to 3 Mbps.
I/O Connector
All available GPIO pins (except for the SPI bus for flash) are broken out to the pin headers on the board. Users can program ESP32-S2FH4 chip to enable multiple functions such as SPI, I2S, UART, 12C, touch sensors, PWM etc. For details, please check the table below.
Reset Button
Reset Button.
Micro-USB Port
USB interface. Power supply for the board as well as the communication interface between a computer and the ESP32-S2FH4 chip.
Boot Button
Download button. Holding down Boot and then pressing Reset initiates firmware Download mode for downloading firmware through the serial port.
RGB LED
Addressable RGB LED (WS2812), driven by GPIO18.
5V to 3.3V LDO
Power regulator that converts a 5 V supply into a 3.3 V output.
Pin Header
The tables below provide the Name and Function of I/O header pins on both sides of the board, the numbering and names are the same as in the schematics in the picture above.
Pin Header of ESP32-S2-DevKitM-1 Development Board
  • ESP32-S2FH4 chip, Xtensa single-core 32-bit LX7 microprocessor
  • 128 KB ROM
  • 320 KB SRAM
  • 16 KB RTC SRAM
  • 40 MHz crystal oscillator
  • 4 MB SPI flash
  • Operating Voltage/Power supply: 3.0~3.6 V
  • Operating Temperature Range: –40~85°C
  • ESP32-S2-DevKitM-1 Demo Board ×1
  • Only 12 Left
