_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
The ESP32-S2-DevKitM-1 is an entry-level development board featuring the ESP32-S2-MINI-1 module. This module integrates the ESP32-S2FH4 chip, which has a Xtensa® single-core 32-bit LX7 microprocessor, 128 KB ROM, and 320 KB SRAM. The board includes 4 MB of SPI flash and provides Wi-Fi (802.11 b/g/n) connectivity. All available GPIO pins are broken out to breadboard-compatible headers. It includes a USB-to-UART bridge for programming and power via a Micro-USB port. An addressable RGB LED (WS2812) is connected to GPIO18.
ESP32-S2-MINI-1 is a generic Wi-Fi MCU module that integrates ESP32-S2FH4 chip. ESP32-S2-MINI-1 comes with a PCB antenna and features a 4 MB SPI flash.
Description of Components
Key Component |
Description |
ESP32-S2-MINI-1 |
ESP32-S2-MINI-1 is a generic Wi-Fi MCU module that integrates ESP32-S2FH4 chip. ESP32-S2-MINI-1 comes with a PCB antenna. And the module features a 4 MB SPI flash. |
3.3 V Power On LED |
Turns on when the USB power is connected to the board. |
USB to UART Bridge |
Single USB-UART bridge chip provides transfer rates up to 3 Mbps. |
I/O Connector |
All available GPIO pins (except for the SPI bus for flash) are broken out to the pin headers on the board. Users can program ESP32-S2FH4 chip to enable multiple functions such as SPI, I2S, UART, 12C, touch sensors, PWM etc. For details, please check the table below. |
Reset Button |
Reset Button. |
Micro-USB Port |
USB interface. Power supply for the board as well as the communication interface between a computer and the ESP32-S2FH4 chip. |
Boot Button |
Download button. Holding down Boot and then pressing Reset initiates firmware Download mode for downloading firmware through the serial port. |
RGB LED |
Addressable RGB LED (WS2812), driven by GPIO18. |
5V to 3.3V LDO |
Power regulator that converts a 5 V supply into a 3.3 V output. |
Pin Header
The tables below provide the Name and Function of I/O header pins on both sides of the board, the numbering and names are the same as in the schematics in the picture above.
