5V RGB Programmable LED Strip (50cm)
$22.90
SKU: FIT0750
  • $22.30 3+ items
  • $21.90 5+ items
  • $21.00 10+ items
COB LED strip offers high brightness, even light distribution, 5V power, programmable RGB, flexible design, easy installation, and Arduino compatibility.
Purchase this product and earn 229 reward points, which are tied to VIP membership program. Learn More >
Compared to the regular LED strip lights, this kind of COB Programmable LED strip comes with advantages of high brightness and density, no light spot, and evenly distributed light.
The flexible LED strip of 50cm is composed of 166 LEDs. The lights emitted by the LED beads can be turned to extremely uniform light of different colors after going through refraction, reflection, and interaction with the phosphor in the encapsulation colloid. It supports 5V power supply, single-wire control, and cascade connection. You can easily use it with Arduino to DIY your favorite lighting effect.
Moreover, this LED strip is extremely flexible and can be bent freely. With adhesive on the back, you can easily fix the LED strip at any place, even in very narrow corners. It can be applied in indoor decoration, advertising, DIY light show, and stylish architectural lighting.
Board Overview
Connect Diagram
  • Uniform and soft light with no light spot
  • 5V Power supply, programmable, full-color RGB
  • Single wire control, support multiple cascades
  • Can be bent freely
  • Rated Voltage: 5V
  • Rated Power: ≤12W
  • LED Type: SK6812
  • LED Number: 166
  • Length: 50cm
  • Single LED Lumens: 100lm
  • LED Chip: 5050
  • Beam Angle: 180°
  • Power Factor: 95%
  • 5V RGB Programmable LED Strip(50cm) x1
    Making a CO2 Concentration Alert Keychain with Infrared SCD41 Photoacoustic Sensor
    Projects Making a CO2 Concentration Alert Keychain with Infrared SCD41 Photoacoustic Sensor
    Frances
    Apr 06, 2023
    DIY Precise Arduino Anemometer with Linear Led Scale - DFRobot
    Projects DIY Precise Arduino Anemometer with Linear Led Scale - DFRobot
    mircemk
    Feb 15, 2022
    Eric.Conn Oct 12, 2025
    As advertised, words great
    Only 15 Left
