Compared to the regular LED strip lights, this kind of COB Programmable LED strip comes with advantages of high brightness and density, no light spot, and evenly distributed light.
The flexible LED strip of 50cm is composed of 166 LEDs. The lights emitted by the LED beads can be turned to extremely uniform light of different colors after going through refraction, reflection, and interaction with the phosphor in the encapsulation colloid. It supports 5V power supply, single-wire control, and cascade connection. You can easily use it with Arduino to DIY your favorite lighting effect.
Moreover, this LED strip is extremely flexible and can be bent freely. With adhesive on the back, you can easily fix the LED strip at any place, even in very narrow corners. It can be applied in indoor decoration, advertising, DIY light show, and stylish architectural lighting.
Board Overview
Connect Diagram
Oct 12, 2025
As advertised, words great
