Black Mecanum Wheel with Motor Shaft Coupling (60mm) - Left
$6.90
SKU: FIT0765
  • $6.80 3+ items
  • $6.70 5+ items
  • $6.50 10+ items
The Mecanum wheel allows smart robots to move in any direction with low noise and flexibility. It's 60mm with 9 silicone-coated rollers.
What wheels should your smart robot car use? How about Mecanum wheel! The Mecanum wheel is an omnidirectional wheel design for a land-based vehicle to move in any direction, such as go straight, obliquely, horizontally, S-line, and rotate at any angle with zero radius.
With pretty low noise, this kind of wheel can move stably and flexibly in operation. Since the wheel is based on omnidirectional drive technology, users can freely control their robot car even in tight space. This Mecanum wheel has a diameter of 60mm and is composed of 9 small rollers that are made of plastic and coated with quality and high-friction silicone rubber, which are rugged and impact-resistant.
Mecanum Wheel Left - Black (60mm)
Note: There are two types of Mecanum wheels: left-handed wheel and right-handed wheel. Please pay attention to the L and R noted on the back of the product when purchasing, and we recommend you to buy them in pairs.
  • Wheel Diameter: 60mm
  • Wheel Thickness: 30.62mm
  • Number of Rollers: 9
  • Angle: 45°
  • Load Capacity: 15kg
  • Color: black
  • Material: plastic + silicone rubber
  • Motor Shaft Coupling Diameter: 6.71mm
  • Motor Shaft Coupling Length: 27.28mm
  • Black Mecanum Wheel (60mm) - Left x1
  • Motor Shaft Coupling x1
    How to Make an Opencv Face Tracking Mecenum Robot Using Unihiker
    Projects How to Make an Opencv Face Tracking Mecenum Robot Using Unihiker
    Afra
    Dec 06, 2023
    Steffen.Lorenz Jan 22, 2025
    Works as expected on my tt dc gearbox motors.
    Only 17 Left
