Black Mecanum Wheel with Motor Shaft Coupling (60mm) - Left
$6.90
SKU: FIT0765
  • $6.80 3+ items
  • $6.70 5+ items
  • $6.50 10+ items
The Mecanum wheel allows smart robots to move in any direction with low noise and flexibility. It's 60mm with 9 silicone-coated rollers.
Black Mecanum Wheel (60mm) – Left enables advanced omnidirectional mobility for small robotic platforms and smart robot cars. A mecanum wheel uses angled rollers to generate lateral and diagonal motion, allowing land-based robots to move forward, sideways, diagonally, or rotate in place with zero turning radius. This 60mm omnidirectional robot wheel is engineered for smooth maneuverability in confined environments where traditional wheels struggle. Compact dimensions and rugged construction make this robotics mobility component suitable for educational robots, experimental autonomous vehicles, and mobile platforms requiring precise directional control.
Note: There are two types of Mecanum wheels: left-handed wheel and right-handed wheel. Please pay attention to the L and R noted on the back of the product when purchasing, and pairing both types together is recommended for proper omnidirectional movement.
True Omnidirectional Motion with 45° Roller Geometry
This omnidirectional robotics wheel integrates nine angled rollers arranged at a 45° orientation, enabling multi-directional movement without changing wheel orientation. Such roller geometry converts rotational force into both longitudinal and lateral motion, supporting movements including straight driving, lateral sliding, diagonal translation, S‑curve navigation, and zero‑radius rotation. This mobility solution greatly improves maneuverability for robotic vehicles operating in narrow pathways, indoor navigation environments, or robotic research platforms requiring agile directional control.
Durable Low‑Noise Construction for Stable Operation
This 60mm mecanum mobility wheel uses plastic structural components combined with high‑friction silicone rubber rollers, providing strong traction while maintaining quiet operation. The roller design absorbs vibration and reduces operational noise during motion. Impact‑resistant materials help maintain structural integrity during repeated robotic testing and continuous movement. A precisely sized motor shaft coupling interface allows reliable mechanical integration with compatible drive motors used in compact robot chassis and educational robotic platforms.
Mecanum Wheel Left - Black (60mm)
Figure: Mecanum Wheel Left - Black (60mm)
Such a compact omnidirectional wheel is well suited for robotic mobility experiments, smart robot car development, automated guided vehicle prototypes, and STEM robotics projects requiring flexible multi‑directional movement. The 60mm robotic wheel size fits small mobile platforms while delivering stable motion, responsive control, and improved navigation performance in research, hobby robotics, and educational environments.
  • 60mm omnidirectional mecanum wheel for multi‑directional robot movement
  • 45° roller arrangement enabling sideways, diagonal, and rotational motion
  • 9 high‑friction silicone rubber rollers for improved traction
  • Low‑noise operation suitable for indoor robotic platforms
  • Durable plastic structure with impact resistance
  • Supports precise maneuvering in confined robotic environments
  • Integrated motor shaft coupling interface for easy installation
  • Smart robot car platforms
  • Omnidirectional mobile robots
  • Automated guided vehicle (AGV) prototypes
  • Robotics research and development
  • STEM robotics projects and education kits
  • Indoor navigation robots
  • Wheel Diameter: 60mm
  • Wheel Thickness: 30.62mm
  • Number of Rollers: 9
  • Angle: 45°
  • Load Capacity: 15kg
  • Color: black
  • Material: plastic + silicone rubber
  • Motor Shaft Coupling Diameter: 6.71mm
  • Motor Shaft Coupling Length: 27.28mm
  • Black Mecanum Wheel (60mm) - Left x1
  • Motor Shaft Coupling x1
    How to Make an Opencv Face Tracking Mecenum Robot Using Unihiker
    Projects How to Make an Opencv Face Tracking Mecenum Robot Using Unihiker
    Afra
    Dec 06, 2023
    Steffen.Lorenz Jan 22, 2025
    Works as expected on my tt dc gearbox motors.
    Only 13 Left
