6-in-1 USB to Serial Converter
$10.90
SKU: FIT0781
  • $10.60 3+ items
  • $10.50 5+ items
  • $10.10 10+ items
The 6-in-1 USB to Serial Converter supports multiple serial conversion functions, has 3.3V/5V compatibility, and is protected against over-current and short-circuit.
Are you troubled by the various level standards and voltages of the serial port? This 6-in-1 USB to Serial Converter is just right for you. Check it out!
One module has six functions. This 6-in-1 multifunctional serial converter supports USB-TTL, USB-232, USB-485, TTL-232, TTL-485, and 232-485 converting functions and is 3.3V/5V compatible. It works well with mainstream operating systems such as Windows and Linux. There is a 500mA fuse protection circuit integrated on the module for protecting the device against damage caused by short-circuit or over-current. The on-board indicator light indicates the working status of the device: USB is selected for the COM port (Yellow light) On, data receiving RX (Red light) Flashes, data transmitting TX (Green light) Flashes.
Mode
Dial switch
1(USB)
Dial switch
2
Switch S1 Diagram
USB to TTL On Off Down(232-485) Diagram
USB to 232 On Off UP(232-TTL) Diagram
USB to 485 On On Down(232-485) Diagram
TTL to 232 Off Off Down(232-485) Diagram
TTL to 485 Off On Down(232-485) Diagram
232 to 485 Off On Down(232-485) Diagram
The module is small and stable. It adopts reliable patch dial switches, a life span of 100,000 times flicks, thus ensuring stable switching of working modes. The module can be widely used in serial communication occasions from USB to other interfaces.
  • Chip: CP2102
  • Compatible with 3.3V/5V voltage input and output
  • Support USB-TTL, USB-232, USB-485, TTL-232, TTL-485, 232-485 six serial conversion
  • Baud Rate: up to 2Mbps
  • Over-current and short circuit protection
  • On-board indicator light indicates working status
  • Support Win8, Win7, WinXp, Win2K, WinCE, Linux, Mac system
  • Size: 3.1cm x 1.8cm / 1.22 x 0.71 inch
  • 6-in-1 USB to Serial Converter x1
