High Precision Handheld Signal Generator
$25.90
SKU: FIT0778
  • $25.00 3+ items
  • $24.50 5+ items
  • $23.90 10+ items
High-precision handheld signal generator with adjustable voltage, current outputs, and protection features. Includes USB cable, screwdriver, and accessories.
DFRobot High Precision Handheld Signal Generator provides a compact solution for accurate voltage and current simulation during electronics testing, calibration, and troubleshooting. This portable signal generation tool delivers adjustable voltage from -10V to +10V and current output up to 22mA with high measurement precision. A bright four‑digit digital display clearly shows output values during adjustment, enabling stable and repeatable signal configuration. Designed for laboratory testing, industrial debugging, and educational experimentation, this handheld voltage and current calibrator simplifies tasks such as motor direction testing, brightness control validation, and modulation signal source evaluation.
Figure: High Precision Handheld Signal Generator
Dual Power Supply for Flexible Field Operation
This portable signal calibration module supports two convenient power input options: Micro USB 5V and external DC 15–30V supply. Such flexibility enables quick deployment in laboratory benches, industrial debugging scenarios, or mobile field diagnostics. USB power provides easy integration with computers or power banks, while the higher‑voltage external input supports more demanding testing environments. Stable power architecture ensures consistent signal output during voltage or current adjustment, allowing engineers and technicians to perform accurate system verification without complex instrumentation setups.
High‑Precision Voltage and Current Signal Generation
This handheld voltage and current source generates analog signals with excellent precision, delivering voltage output from -10V to +10V and current output from 0–22mA. Voltage accuracy reaches 0.05V while current accuracy reaches 0.05mA, supporting reliable calibration and debugging tasks. Linear output characteristics allow fine control during signal simulation, while calibration capability maintains long‑term measurement consistency. Such performance makes this compact signal generator suitable for validating industrial controllers, analog interfaces, sensors, and modulation hardware.
Multiple Adjustment Modes with Clear Digital Feedback
Three output adjustment modes provide flexible control during signal configuration: coarse adjustment for rapid changes, fine adjustment for precise tuning, and customizable quick adjustment for frequently used values. A high‑brightness four‑digit digital tube display continuously presents the output level, enabling intuitive monitoring during operation. This control interface significantly improves usability during calibration workflows, hardware testing, and prototype debugging where accurate incremental signal changes are essential.
Industrial Protection and Multi‑System Compatibility
This compact signal output instrument supports both passive and active current output modes and remains compatible with common 2‑wire, 3‑wire, and 4‑wire industrial systems. Integrated safety mechanisms include output short‑circuit protection and reverse power connection protection, safeguarding both the signal generator and connected equipment during testing. Such reliability makes this handheld calibration tool suitable for laboratory electronics work, industrial automation maintenance, and engineering development environments.
Typical uses include motor forward and reverse rotation debugging, LED brightness control verification, analog signal simulation, industrial controller testing, and voltage or current calibration during product manufacturing and maintenance processes.
  • Portable high‑precision handheld voltage and current signal generator
  • Adjustable voltage output range: -10V to +10V
  • Adjustable current output range: 0–22mA
  • High accuracy: 0.05V voltage accuracy, 0.05mA current accuracy
  • Three adjustment modes: coarse, fine, and custom quick adjustment
  • Bright 4‑digit digital display for real‑time output monitoring
  • Supports passive and active current output
  • Compatible with 2‑wire, 3‑wire, and 4‑wire systems
  • Dual power supply: Micro USB 5V or external DC 15–30V
  • Built‑in short‑circuit protection and reverse polarity protection
  • Motor forward and reverse rotation debugging
  • LED brightness and lighting control testing
  • Analog signal simulation and calibration
  • Industrial controller testing
  • Voltage and current output verification in manufacturing
  • Electronic circuit troubleshooting and development
  • Power Supply: Micro USB-5V, external DC15-30V
  • Output Voltage: -10~+10V
  • Output Current: 0~22mA
  • Voltage Accuracy: 0.05V
  • Current Accuracy: 0.05mA
  • Protection Mechanism: output short circuit protection, power supply reverse connection protection
  • Size: 100*60*20mm / 3.94*2.36*0.79inches
  • High Precision Handheld Signal Generator x1
  • Micro USB Cable x1
  • Screwdriver x1
  • User Manual x1
  • Accessories Pack (Alligator clip, connector, etc) x1
