4-way Fast Charge Buck Module (Compatible with Raspberry Pi 4B & Jetson Nano)
$7.90
SKU: DFR0852
A 4-port USB fast-charging module compatible with most phones, supports multiple protocols, and offers stable voltage output. Ideal for various charging projects.
DFRobot 4‑Way Fast Charge Buck Module is a compact multi‑port DC‑DC step‑down power board designed for high‑efficiency USB charging applications. The fast‑charging power module integrates intelligent 5V charging recognition and supports a wide range of mobile devices on the market. Operating from a 6–32V input supply and delivering 3–12V output depending on the detected fast‑charging protocol, this multi‑USB DC buck converter enables rapid charging while maintaining stable voltage regulation. Four independent USB channels allow simultaneous charging or powering of multiple electronics, making the board suitable for portable power systems, automotive upgrades, and custom power distribution projects.
Figure: 4-way Fast Charge Buck Module
Integrated Fast‑Charging Recognition
Built‑in charging identification circuitry activates peak current through supported fast‑charging protocols, significantly reducing charging time compared with standard USB power modules lacking protocol detection. Compatibility with major smartphone charging standards enables efficient power negotiation between connected devices and the charging board. Automatic protocol detection allows the multi‑port charger board to deliver optimized voltage and current levels without manual configuration, ensuring reliable high‑speed charging for a wide range of consumer electronics.
Wide Input Buck Conversion
A high‑efficiency step‑down architecture supports a broad 6–32V input range, making the DC‑DC converter board suitable for vehicle power systems, solar energy setups, and industrial DC sources. Output voltage automatically adjusts between 3–12V depending on the negotiated fast‑charging protocol, with a default 5V output when protocol negotiation is not triggered. Flexible voltage behavior allows the charging module to function both as a dedicated USB charger and as a regulated power supply for embedded electronics.
Four Independent USB Output Channels
The multi‑port charging module integrates four USB outputs operating independently, allowing simultaneous connection of multiple devices without interference between channels. Each port negotiates charging protocols individually, enabling different voltage requirements across connected electronics. Such architecture is particularly useful in shared charging environments, embedded system power hubs, and multi‑device battery charging stations where stable distribution of power across several outputs is required.
Stable Long‑Term Operation with Integrated Protection
Stable voltage regulation ensures reliable long‑duration operation without noticeable output drift. Integrated protection mechanisms include input over‑voltage protection, under‑voltage protection, input over‑current protection, output over‑current protection, short‑circuit protection, and thermal protection for the entire board. These safeguards improve reliability when the power module is used in demanding environments such as automotive electrical systems, DIY battery packs, or continuously operating charging stations.
Typical applications include mobile phone fast‑charging systems, vehicle USB charger retrofits, solar‑powered charging stations, and DIY regulated power sources. The compact four‑port fast‑charge buck converter also fits well in portable power projects, custom electronics enclosures, and distributed USB charging hubs where efficient multi‑device power delivery is required.
  • Four independent USB output ports
  • Supports multiple fast‑charging protocols
  • Functions as both charger and regulated power supply
  • Mobile phone fast charging systems
  • Automotive USB charger retrofit
  • Solar charging projects
  • DIY regulated power supplies
  • Portable multi-device charging hubs
  • Input Voltage Range: 6V-32V
  • Output Voltage: 3-12V, automatically adjust according to the fast-charge protocol (the default output is 5V, input should be 2V higher than output)
  • Output Current: 0-3A
  • Output power: ≤24W ([email protected], [email protected], 12V@2A, etc.)
  • Chip Protection: input over-voltage, under-voltage protection, input over-current protection, output over-current, short-circuit protection, over-temperature of the whole machine protection
  • Fast-charging Protocol:
      Support DCP protocol, BC1.2, Apple, Samsung protocol
      Support Huawei fast-charging protocol FCP/SCP, AFC
      Support Spreadtrum fast-charging protocol SFCP
      Support Qualcomm QC2.0 and 3.0
      Support MTKPE1.1/PE2.0
  • 4-way Fast Charge Buck Module x1
  • 4-way Fast Charge Buck Module (Compatible with Raspberry Pi 4B & Jetson Nano)
