Amphibious Horizontal Submersible Pump
$2.90
SKU: FIT0800
This amphibious pump is ideal for fountains, water changing, or plant watering projects. It's low noise, efficient, easy to clean, and waterproof.
Use this amphibious micro submersible pump to build a small fountain, make auto water changer, or DIY plant-watering project!
This product is powered by 3-6V and has the characteristics of low noise, high efficiency, and easy cleaning. With an IP68 waterproof rating, the pump can be immersed into water, but the water level should be higher than the pump. Or you can just connect water pipes to the pump water inlet and outlet to move water from here to there.
  • Power Supply Voltage: DC 3-6V
  • Current: 150~370mA
  • Pump Lift: 25-45cm
  • Flow: 80-100L/H
  • Power: 0.4~2W
  • Water Inlet and Outlet: 5mm/0.20”
  • Amphibious Horizontal Submersible Pump x1
  • Pipe 1m x1
  • Review
    kyle.benson May 10, 2023
    Very fast shipping. Thanks!
