This is an E Ink display controller featuring a 4.7-inch screen with 540x960 resolution, 16-level grayscale, and partial refresh support. It is powered by an ESP32-S3-WROOM-1-N16R18 controller with 16MB Flash and 8MB PSRAM. The board includes two customizable buttons, a PH 2.0 battery connector with a charge/discharge protection chip (HX6610S), and a 40-pin header compatible with the Raspberry Pi BUS interface. It also provides a 6-pin interface intended for connecting a touchscreen panel (touchscreen not included).
In comparison to a regular LCD screen, an E Ink display provides users with a better text reading experience, along with low power consumption and image retention when powered off. It also includes a 6-pin touchscreen interface for optional accessories, catering to your specific application needs. On the side, there are 3 reserved buttons, with 2 customizable buttons for flexible functionality and one reset button. Additionally, it features a 40-pin header compatible with Raspberry Pi's BUS interface. On the back, there is a PH 2.0 spaced 3.7V battery socket.
Note: This E-ink display compatible 4.7" Capacitive Touchscreen Panel has been discontinued.
Board-Overview
