USB Cable and Charger Tester with 1.44" TFT LCD Color Screen delivers portable power analysis, fast‑charge protocol detection, and real‑time electrical monitoring in a compact handheld format. A built‑in 1.44‑inch high‑definition TFT display presents voltage, current, power, capacity, and waveform curves clearly during operation. An external 16‑bit ADC combined with a dedicated PD protocol physical chip enables accurate measurement and protocol identification. Multiple integrated interfaces—USB‑A, Micro‑USB, and Type‑C—support diverse testing scenarios including adapter verification, cable evaluation, and charging performance diagnostics for USB‑powered electronics.
Figure: USB cable and charger tester with TFT color display
Note: Input voltage must not exceed 24V. USB‑A input supports high‑power loads up to 100W (20V×5A) while the USB‑A output port tolerates 5A only for short durations. Micro‑USB input does not support high current and should remain below 2.5A. Type‑C output is recommended for high‑power testing scenarios. HID‑USB interface functions solely for data transmission. High‑power operation may raise tester temperature; caution required to prevent burns. All ports operate in parallel except online ports, and only one input and one output connection should be active simultaneously.
Real-Time Power Monitoring with Color Waveform Display
This compact USB power measurement instrument integrates a 1.44‑inch TFT color screen capable of displaying voltage, current, power, capacity, and energy consumption simultaneously. Real‑time curve visualization allows engineers and makers to observe charging behavior dynamically, enabling immediate detection of abnormal fluctuations or unstable adapters. A high‑precision 16‑bit ADC improves sampling accuracy, making this USB electrical diagnostic tool suitable for evaluating chargers, cables, and USB power supplies during development, repair, or hardware verification tasks.
Fast-Charge Protocol Detection and PD Trigger Capability
An integrated PD protocol physical chip enables automatic recognition of multiple fast‑charging standards while supporting protocol conversion and decoy triggering. This fast‑charging analysis module can actively request higher voltage levels from compatible adapters, enabling quick verification of PD or quick‑charge capability. Protocol monitoring combined with high‑voltage trigger functionality also allows the creation of a simple adjustable DC power output when paired with compatible protocol adapters.
Multi-Interface Design for Flexible Testing
A versatile hardware layout integrates USB‑A, Micro‑USB, and Type‑C ports, allowing the portable USB diagnostic meter to connect easily with chargers, cables, power banks, and embedded devices. Horizontal and vertical screen rotation improves readability during different installation orientations, while dual‑language interface switching (Chinese and English) supports broader usability across development environments, laboratories, and electronics repair workstations.
Advanced Cable and Resistance Analysis
Beyond standard power measurement, this USB testing instrument supports wire resistance testing and internal resistance calculation, enabling deeper cable quality evaluation. Load equivalent resistance measurement, capacity accumulation, and energy tracking provide comprehensive insight into charging efficiency and cable performance. Such diagnostic capabilities assist hardware developers, technicians, and electronics enthusiasts in identifying poor‑quality cables, inefficient adapters, or unstable charging conditions.
Typical usage includes measuring USB interface power consumption, evaluating mobile phone charging performance, verifying adapter fast‑charge compatibility, and testing cable resistance characteristics. Portable form factor and multi‑protocol support make this color screen USB tester valuable for electronics debugging, repair benches, hardware validation workflows, and field diagnostics involving USB‑powered devices.
