Are you bothered by the heat problem of the Raspberry Pi? Don't worry, we have prepared a set of heat dissipation solutions for Raspberry Pi 4B. These black aluminum heat sinks of various sizes adopt a slotted design on the surface, which is more conducive to heat dissipation. They also come with adhesive backing for easy installation.
Note: The product not include Raspberry Pi 4B board.
Black heat sink with adhesive (large): 40 * 30 mm / 1.57 * 1.18 inch
Black heat sink with adhesive (middle): 14.5 * 10 mm / 0.57 * 0.39 inch
Black heat sink with adhesive (small): 9 * 9 mm / 0.35 * 0.35 inch
