Black Aluminum Heatsink Kit for Raspberry Pi 4B
$2.50
SKU: FIT0818
Black aluminum heat sinks for Raspberry Pi 4B, designed for effective heat dissipation with adhesive backing for easy installation. Raspberry Pi 4B not included.
Raspberry Pi 4B Aluminum Heat Sink Set provides an efficient passive cooling solution for compact single-board computing platforms. Designed specifically for Raspberry Pi environments, this thermal management kit includes multiple aluminum heat sinks sized to match key chips on the Raspberry Pi 4B. A precision slotted surface structure increases exposed area for improved airflow and heat transfer. Pre‑applied adhesive backing simplifies installation while maintaining reliable thermal contact. This compact cooling accessory helps stabilize processor temperature during extended workloads, embedded development, robotics control tasks, and continuous computing applications.
Figure: Aluminum heat sink set designed for Raspberry Pi 4B cooling
Note: The product not include Raspberry Pi 4B board.
Slotted Aluminum Surface for Enhanced Heat Dissipation
Each cooling block features black anodized aluminum combined with a slotted top structure that increases effective surface area for heat exchange. The grooved geometry improves airflow contact compared with flat metal plates, allowing faster thermal transfer away from high‑temperature components such as the CPU, RAM, and USB controller. This passive thermal design supports stable operation during heavy computation, media processing, or embedded AI workloads without introducing noise or additional power consumption.
Multiple Sizes for Targeted Chip Cooling
The thermal kit includes large, medium, and small aluminum heat sinks sized to match different integrated circuits on the board. This multi‑dimension configuration enables optimized cooling coverage across the main processor and supporting chips. By distributing heat dissipation across several components rather than a single cooling block, the compact heat management solution helps reduce thermal buildup and improves overall system stability for development boards, automation projects, and continuous operation setups.
Adhesive‑Backed Installation for Quick Deployment
Pre‑applied thermal adhesive simplifies the installation process while maintaining secure contact between aluminum heat sinks and chip surfaces. The integrated adhesive layer removes the need for screws, brackets, or additional mounting hardware, making the cooling upgrade fast and convenient. This plug‑and‑apply design suits compact electronics assemblies, maker prototypes, robotics controllers, and educational computing platforms where mechanical simplicity and reliable heat transfer are essential.
Compact passive cooling components like this aluminum heat sink kit are widely used in embedded computing, robotics control systems, edge computing gateways, media centers, and STEM Education development platforms. Reliable thermal management helps maintain processor performance and extends hardware lifespan during long operating cycles.
  • Designed for Raspberry Pi 4B thermal management
  • Black anodized aluminum construction for efficient heat transfer
  • Slotted surface design improves heat dissipation area
  • Pre‑applied adhesive backing for simple installation
  • Multiple heat sink sizes for cooling different onboard chips
  • Passive cooling solution with zero noise and no power consumption
  • Raspberry Pi 4B thermal management
  • Embedded computing systems
  • Robotics controllers
  • Media center devices
  • IoT gateways and edge computing nodes
  • STEM Education development projects
  • Size
  •     Black heat sink with adhesive (large): 40 * 30 mm / 1.57 * 1.18 inch
        Black heat sink with adhesive (middle): 14.5 * 10 mm / 0.57 * 0.39 inch
        Black heat sink with adhesive (small): 9 * 9 mm / 0.35 * 0.35 inch
  • The heat sink comes with adhesive
  • Material: black aluminum material
  • Black heat sink with adhesive (large) x1
  • Black heat sink with adhesive (middle) x1
  • Black heat sink with adhesive (small) x2
  • Only 15 Left
