Flexible LED Filament (3V 260mm, Red, 5 Pack)
$12.50
SKU: FIT0808
  • $12.10 3+ items
  • $11.90 5+ items
  • $11.50 10+ items
A flexible LED filament chip, 260mm long, bendable, emitting 360-degree light with 3V power. Ideal for DIY lighting projects and decorations.
Purchase this product and earn 125 reward points, which are tied to VIP membership program. Learn More >
This flexible LED filament Chip comes with a diameter of 2mm and a length of 260mm. The small round hole end is the positive electrode, and the non-porous end is the negative electrode. The filament is flexible and can be bent and folded at will. With a 3V power supply, it emits light 360 degrees. They can be used for DIY lighting decoration, DIY bulb ball, 360° full-angle light-emitting lamps, etc.
3V 260mm Flexible LED Filament Chip
Dimension
  • 3V power supply, high brightness, suitable for DIY
  • Small size, separate negative and positive electrodes
  • Flex LED filament chip, can be bent and folded at will
  • Length: 260mm/10.24”
  • Supply Voltage: 3V
  • Operating Current: <0.2A
  • 3V 260mm Flexible LED Filament Chip (Red) x5
  • Only 7 Left
